Old 01-28-2021, 11:16   #16 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
Originally Posted by amr_ibrahim View Post
yes there is error while smart reset
screenshot of error + identify log
init memory tool
read
PGPT
nvdata
pro info
protect 1
boot
recovery
zip all and upload somewhere send link
Old 01-28-2021, 11:45   #17 (permalink)
Member: 2824001
Thanks Meter: 110
Jaydi Sir, make this machine learning based on cloud basis means one time operation proceeded benefited for all users around the globe. i can not explaining my view but i hope you can understand what am saying. the simple advise is make a blockchain or interconnected SW.
Br,
Jameel91
Old 01-28-2021, 11:46   #18 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Originally Posted by boganice View Post
Error Oppo A83 CPH1729 selected perloader only, and more time both.
Operation : HW Report [ v2.19 ]
HWreport : Mode : eMMC
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM57)
MODE : PRELOADER PORT
PORT : 57
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
     CODE : Bianco
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : BROM|BL  : 0xFF|0x02
BROM : PRELOADER PORT
MODE : 0_base : BASE_v2044 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6763
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
  BROM  : 0x00002001 : DA SEND ERROR!
  ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
  INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC
Info : LEGACY : HW reporting feature unavailable for current device!
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Done!
Elapsed: 00:00:40
When I chose OPPO F5 Type:
PORT : 57
BROM : Init BROM
BROM init passed!
     CODE : Bianco
MODE : Oppo : F5 | Manual : Disabled
AGENT : DA_PL_CRYPTO.bin
Done!
Elapsed: 00:00:22
Also new window didn't appear !!
thx. wait new action
You need connect device in BROM mode to get all features working!
The Following User Says Thank You to JayDi For This Useful Post:
Old 01-28-2021, 12:48   #19 (permalink)
boganice's Avatar
Member: 5184
Thanks Meter: 246
BROM = No action !!
I've tried with boot keys and without..
Old 01-28-2021, 13:34   #20 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Outstanding Thankxxxxxxx CM2 Team
Old 01-28-2021, 13:41   #21 (permalink)
Member: 2937153
Thanks Meter: 103
With v2.19 we bring new way to make your life easy.
If you get new/unknown device, which you need service and it build on new platfrom ( we call it RAPHAEL ) you need have correct boot configuration.
Till now were required to select preloader or make HWreport.
Now it look another...
If you boot device and see such message from software, when do some operation :
DO NOT PANIC!!!!
That is completely okay!
Just repeat need operation ONE MORE TIME!
After self-learn software will not ask anything more for that device. You can proceed with need service actions.
It is main working case. But sometimes you may get more strange and scary message :
DO NOT PANIC!!!!
Maybe, it ask 1-2 more time. 3 is an maximum.
After repeat you should get such message :
DO NOT PANIC!!!!
That is completely okay! And mean software found, learned and ready to service your device!
After you will get result :
So, 1-3 clicks required sometimes
So now is MEIZU devices supported???
Old 01-28-2021, 14:13   #22 (permalink)
JayDi's Avatar
Member: 462970
Yes, they are supported now.
Old 01-28-2021, 14:14   #23 (permalink)
JayDi's Avatar
Member: 462970
BROM = No action !!
You need do TestPoint, if device wont boot with just keys. Yes, need open phone.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 01-28-2021, 18:02   #24 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,250
What does it mean?
Operation : Identify [ v2.19 ]
Mode : FLASH
PTFN : MediaTek USB Port (COM27)
MODE : BOOTROM
PORT : 27
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
     CODE : Merlot
BROM : MEID : A4EDB161F79DD81D37A5021E2D3E68B6
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : BROM|BL  : 0x05|0xFE
BROM : BOOTROM
BROM : SOCID : B73E7C1ED756AE85654A19F15AA76472FCA64099B8ED6A485F779DA3FE4C53F0
AGENT : Found MT6761
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD?
>>> Check and select CORRECT SETTINGS for your device!
Old 01-28-2021, 18:39   #25 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by ribbentrop View Post
What does it mean?
Mode : FLASH
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
     CODE : Merlot
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
Try install new driver variant from support area. We found it most stable in case of some system HW/SW configurations.
https://www.infinity-box.com/support...tware/drivers/
It is mandatory after new drivers - connect device to software once, then restart software and do need operations.
Old 01-28-2021, 18:59   #26 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,250
Sorry, my fault... You're right )))
Mode : FLASH
PTFN : MediaTek USB Port_V1632 (COM27)
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
     CODE : Merlot
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : INFINITY
     EMI : SRC : PRELOADER_INFINITY_0
     EMI : CNT : 0001
     EMI : Init EMI from INTERNAL DB
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x0003A000 [ 232,00 KB ]
        DRAM: 0x40000000 [ 1,00 GB ]
        EMMC: 700100544132383332200BC7446D6645
        EMMC: VEN : KINGSTON | OEM : 01 | DEV : TA2832
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00400000 [ 4,00 MB ]
              USER   : 0x74A000000 [ 29,16 GB ]
        CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : B371886D21D6537DE6C985AA9D27FDB2
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : PPR1.180610.011
Display ID     : BSQ06_TP7062_V06_20200106
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2020-01-05
Build Time     : 06.01.2020
Product Model  : Neffos C9 Max
Product Brand  : Neffos
Product Name   : TP7062A
Product Info   : TP7062A
Product Device : C9_Max
Product Manfct : TP-Link
Product Board  : yk676v1_lwg61_32
Board Platform : mt6761
USERDATA : FILESYSTEM : F2FS  with FDE ( Full Disk Encryption *)
NVRAM check : Passed!
NVRAM : SEC NORMAL  [ No extra security ]
Backup sensetive data [ 10 ]
Backup path : Backup\MT6761__B371886D21D6537DE6C985AA9D27FDB2\
[23] Read : NVRAM
[8] Read : NVDATA
[14] Read : PROINFO
[24] Read : LK
[7] Read : NVCFG
[10] Read : PROTECT1
[11] Read : PROTECT2
[0] Read : PRELOADER
Backup done!
STORAGE : LifeStatus : eMMC : OK!
PRELOADER : DEVICE :
DEV : MT6761
NME : preloader_yk676v1_lwg61_32.bin
CNT : 0003
 EMI : [00] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 512,00 MB ]
 EMI : [01] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 2,00 GB ]
 EMI : [02] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 2,00 GB ]
Done!
Elapsed: 00:00:32
Old 01-28-2021, 19:18   #27 (permalink)
Member: 1034743
Sonork: 100.1619212
Thanks Meter: 193
Boom boom update 1.58 after 2.17/18/19 .
2021 new year 1st month gift for cm2 user,
i hope daily month gift any new somethink futures,
Thank you for the best update
Old 01-28-2021, 20:30   #28 (permalink)
ganjbek's Avatar
Member: 1246378
Thanks Meter: 123
sir pls add meta rsa imei repair mode >>
The Following User Says Thank You to ganjbek For This Useful Post:
Old 01-29-2021, 08:24   #29 (permalink)
Member: 2958962
Thanks Meter: 28
Oppo A15 CPH2185 Boot Done but smart reset failed
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.20
Load IDBase v125162 Ok!
Operation : HW Report [ v2.20 ]
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
BROM : MEID : AA7783F2AF7B257EFFA5F144D843657A
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BOOTROM
BROM : SOCID : 8F9CB31E12D223170B9CCC1E6FD941FFABC9F860BE948E823A 08F6A20C4EB5A7
BROM : SLA : Local Auth
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Found MT6765
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0004
DA : SETUP EMI PARAMS FAILED!
ERROR : ABORT
Boot done!
Memory Info :
CID : 90014A68423861503E030016B720A7A9
MEM : VEN : HYNIX | OEM : 4A01 | DEV : hB8aP>
DAT : Size: 29820 MB, Max.Speed: 52000 kHz, blklen(512), nblks(61071360), ro(0)
EXT_CSD Info :
EXT_CSD rev. : v1.8 ( MMC v5.1 )
CSD struct rev. : v1.2
Supported command sets : 1h
HPI features : 1h
BG operations support : 1h
BG operations status : 0h
Correct prg. sectors : 0h
1st init time after part. : 1000 ms
Min. write perf.(DDR,52MH,8b): 0h
Min. read perf. (DDR,52MH,8b): 0h
TRIM timeout: 0 ms
Secure feature support: 55h
Secure erase timeout : 150000 ms
Secure trim timeout : 150000 ms
Access size : 3584 bytes
HC erase unit size : 512 kbytes
HC erase timeout : 600 ms
HC write prot grp size: 8192 kbytes
HC erase grp def. : 0h
Reliable write sect count: 1h
Sleep current (VCC) : 8h
Sleep current (VCCQ): 9h
Sleep/awake timeout : 419430400 ns
Sector count : 3a3e000h
Min. WR Perf. (52MH,8b): 78h
Min. Read Perf.(52MH,8b): 8ch
Min. WR Perf. (26MH,8b,52MH,4b): 46h
Min. Read Perf.(26MH,8b,52MH,4b): 46h
Min. WR Perf. (26MH,4b): 1eh
Min. Read Perf.(26MH,4b): 1eh
Power class: 0
Power class(DDR,52MH,3.6V): 0h
Power class(DDR,52MH,1.9V): 0h
Power class(26MH,3.6V) : 0h
Power class(52MH,3.6V) : 0h
Power class(26MH,1.9V) : 0h
Power class(52MH,1.9V) : 0h
Part. switch timing : 1h
Out-of-INTR busy timing: ah
Card type : 57h
Command set : 0h
Command set rev.: 0h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 2h
Boot area write prot : 0h
User area write prot : 0h
FW configuration : 0h
RPMB size : 16384 kbytes
Write rel. setting : 1fh
Write rel. parameter: 15h
Start background ops : 0h
Enable background ops: 2h
H/W reset function : 1h
HPI management : 0h
Max. enhanced area size : 747h (15261696 kbytes)
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
General purpose 1 size : 0h (0 kbytes)
General purpose 2 size : 0h (0 kbytes)
General purpose 3 size : 0h (0 kbytes)
General purpose 4 size : 0h (0 kbytes)
Enh. user area size : 0h (0 kbytes)
Enh. user area start: 0h
Bad block mgmt mode: 0h
Overall status :
MLC status : 0% - 10% used
SLC status : Not defined
EOL status : Normal ( Less than 80% reserved blocks used )
Done!
Elapsed: 00:01:00
Other identy/reset fail
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0004
ERROR : ABORT
Boot done!
Memory Info :
EXT_CSD Info :
HPI features : 1h
TRIM timeout: 0 ms
Power class: 0
Card type : 57h
Command set : 0h
HS timing : 0h
Bus width : 0h
Boot bus width : 2h
HPI management : 0h
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
Overall status :
Done!
Elapsed: 00:01:00
Operation : Reset Settings/Format FS [ v2.20 ]
Mode : SMART RESET
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0004
ERROR : ABORT
Boot done!
Done!
Elapsed: 00:00:53
Operation : Identify [ v2.20 ]
Mode : FLASH
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : SRC : PRELOADER_INFINITY_1
EMI : CNT : 0008
ERROR : ABORT
Boot done!
Done!
Elapsed: 00:00:40
Mode : FLASH
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : SRC : PRELOADER_INFINITY_2
EMI : CNT : 0008
ERROR : ABORT
Boot done!
Done!
Elapsed: 00:00:43
Mode : FLASH
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : SRC : PRELOADER_INFINITY_3
EMI : CNT : 0001
DA : BOOT 2ND DA FAILED!
ERR : 0xC0070004
ERR : DA_HASH MISMATCH
Boot done!
Done!
Elapsed: 00:00:49
Mode : FLASH
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
ERR : 0xC0070004
Mode : SMART RESET
MODE : BOOTROM
PORT : 27
Error : Failed to open port!
Mode : SMART RESET
MODE : BOOTROM
PORT : 27
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
ERR : 0xC0070004
Old 01-29-2021, 09:25   #30 (permalink)
Member: 2211790
Thanks Meter: 5,118
Set EMI Default 0
do identify 2 time
what result ?
Page generated in 0.31142 seconds with 9 queries
