02-01-2021, 02:53 | #46 (permalink) |
Junior Member Join Date: May 2017
Member: 2716325 Status: Offline Thanks Meter: 2 | Quote: thanks for this tutorial work around.. |
02-03-2021, 16:47 | #49 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 201238 Status: Offline Thanks Meter: 24 | infinix x690 reset ok report Card found : ECFF56E3 , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v21168 Ok! Operation : HW Report [ v2.21 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM111) MODE : BOOTROM PORT : 111 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 0E701117A22CFF59C983C04D0EDE54CE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 75BB8AD230C79089CF71150769037A85E98C2B1B54FEF6D59C D83B75AC5EAFB6 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 13014E53304A394B39101DC7D1D4570F EMMC: VEN : MICRON | OEM : 4E01 | DEV : S0J9K9 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : C4A498922956ABFB41D9F4D36DBD57E2 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 13014E53304A394B39101DC7D1D4570F MEM : VEN : MICRON | OEM : 4E01 | DEV : S0J9K9 DAT : Size: 119280 MB, Max.Speed: 52000 kHz, blklen(512), nblks(244285440), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 3000 ms Min. write perf.(DDR,52MH,8b): 80h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 60000 ms Secure trim timeout : 60000 ms Access size : 4608 bytes HC erase unit size : 512 kbytes HC erase timeout : 600 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 8h Sleep current (VCCQ): 8h Sleep/awake timeout : 419430400 ns Sector count : e8f8000h Min. WR Perf. (52MH,8b): 80h Min. Read Perf.(52MH,8b): 0h Min. WR Perf. (26MH,8b,52MH,4b): 4eh Min. Read Perf.(26MH,8b,52MH,4b): 0h Min. WR Perf. (26MH,4b): 2bh Min. Read Perf.(26MH,4b): 0h Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 3h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 16384 kbytes Write rel. setting : 1fh Write rel. parameter: 15h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 1368h (40697856 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE] Done! Elapsed: 00:00:28 Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM111) MODE : BOOTROM PORT : 111 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 0E701117A22CFF59C983C04D0EDE54CE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 75BB8AD230C79089CF71150769037A85E98C2B1B54FEF6D59C D83B75AC5EAFB6 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 13014E53304A394B39101DC7D1D4570F EMMC: VEN : MICRON | OEM : 4E01 | DEV : S0J9K9 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : C4A498922956ABFB41D9F4D36DBD57E2 DA : USB : HIGH-SPEED Boot done! Done! Elapsed: 00:00:32 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM111) MODE : BOOTROM PORT : 111 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 0E701117A22CFF59C983C04D0EDE54CE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 75BB8AD230C79089CF71150769037A85E98C2B1B54FEF6D59C D83B75AC5EAFB6 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 13014E53304A394B39101DC7D1D4570F EMMC: VEN : MICRON | OEM : 4E01 | DEV : S0J9K9 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : C4A498922956ABFB41D9F4D36DBD57E2 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825657 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to khurram6230 For This Useful Post: |
02-07-2021, 05:46 | #50 (permalink) |
Junior Member Join Date: Jul 2012 Location: Moanda-GABON
Member: 1791906 Status: Offline Thanks Meter: 2 | please can somebody help me with this issue, i am unable to write nvram with this. the dialogue propose this format mt_sec but i don't know exactly what to do. |
02-07-2021, 15:01 | #51 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | NVRAM in binary format you can write over MEMORY TOOL or via enable EXTENDED option in flashing tab, then select scatter and specify NVRAM file. Also, filter of extension allow change it to BIN format also. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
02-12-2021, 05:29 | #54 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | i am trying redmi 6a to read what am i doing wrong or what do i need to do? Code: Card found : 6359E774 , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v21168 Ok! Operation : HW Report [ v2.21 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : AE7BF21B4893134D12953E85A7E8941C BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 7021FA2C6EFD8E08869129D201D35CAC8F0F57F7D3A95086E670BA79794EDE59 BROM : SLA : Local Auth Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Info : LEGACY : HW reporting feature unavailable for current device! Done! Elapsed: 00:00:20 Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : AE7BF21B4893134D12953E85A7E8941C BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 7021FA2C6EFD8E08869129D201D35CAC8F0F57F7D3A95086E670BA79794EDE59 BROM : SLA : Local Auth Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : AE7BF21B4893134D12953E85A7E8941C BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A | Manual : Disabled BROM : SOCID : 7021FA2C6EFD8E08869129D201D35CAC8F0F57F7D3A95086E670BA79794EDE59 BROM : SLA : Local Auth Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : AE7BF21B4893134D12953E85A7E8941C BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A | Manual : Disabled BROM : SOCID : 7021FA2C6EFD8E08869129D201D35CAC8F0F57F7D3A95086E670BA79794EDE59 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : HW Report [ v2.21 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : AE7BF21B4893134D12953E85A7E8941C BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A | Manual : Disabled BROM : SOCID : 7021FA2C6EFD8E08869129D201D35CAC8F0F57F7D3A95086E670BA79794EDE59 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Info : LEGACY : HW reporting feature unavailable for current device! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Done! Elapsed: 00:00:10 |
02-12-2021, 22:12 | #55 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
05-23-2021, 19:56 | #59 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | FireFly Core activated. Not need care anymore about correct preloader for 90% of supported models. Old type : Code: Operation : Identify [ v2.24 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : EMI : DevInit BROM : EMI : DevInit Ok! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 44000145303034476BDxxxxxxxxxxxx DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 45010044473430303801xxxxxxxxxxxxxxx NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_bird_o1mp2_k80_bsp_512m.bin EMI : CNT : 0001 INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x20000000 [ 512,00 MB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 450100444734303038xxxxxxxxxxxxxx EMMC: VEN : SANDISK | OEM : 01 | DEV : DG4008 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x1D21D0000 [ 7,28 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x20000000 [ 512,00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Boot done! Patch Level : O11019 Display ID : 7130D_S8020K_E.A1.20180808.AD80.V21.WVGA.DS84.B18.MP.RU Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-07-05 Build Time : 08.08.2018 Product Info : Impress_Funk Product Model : Impress_Funk Product Brand : Vertex Product Name : Impress_Funk Product Device : Impress_Funk Product Board : Impress_Funk Product Manfct : Vertex Board Platform : mt6580 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) IMEI[0] : 35xxxxxxxxxxxxxxx IMEI[1] : 35xxxxxxxxxxxxxxx NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 14 ] Backup path : Backup\MT6580__xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\ Backup done! PRELOADER : DEVICE : DEV : MT6752 NME : preloader_bird_o1mp2_k80_bsp_512m.bin CNT : 0001 Done! Elapsed: 00:00:52 Code: Operation : Read Firmware [ v2.24 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : EMI : DevInit BROM : EMI : DevInit Ok! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k61v1_32_bsp_hdp.bin EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514531334D420xxxxxxxxxxxx EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Product Brand : Ulefone Product Device : Armor_X7_Q Product Model : Armor X7 Product Name : Armor_X7_Q_EEA Patch Level : QP1A.190711.020 Display ID : P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0114.V3.03 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-12-05 Build Time : 14.01.2021 Product Info : Armor_X7_Q Product Board : Gotron-GQ3087SH2 Board Platform : mt6761 Product Manfct : Ulefone Display ID : P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03 MT6761__10__P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03__QP1A.190711.020__Armor_X7_Q Read : preloader.bin Read : proinfo.img Read : recovery.img Read : vbmeta_system.img Read : vbmeta_vendor.img Read : seccfg.img Read : persist.img ExtSparse : Compression ratio : 100% Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : super.img ExtSparse : Compression ratio : 45% Read : vbmeta.img Read : cache.img Read : userdata.img FW Size : 2,42 GB Android Info saved : _Android_info.txt Scatter : MT6761_Android_scatter.txt Saved to : C:\MTK\MT6761__10__P2NQS62EE7.GQU2.Ulefone.EEA.HB.HD.HWS5VJ.0122.V3.03__QP1A.190711.020__Armor_X7_Q\ Done! Elapsed: 00:07:28 New : Code: Operation : Identify [ v2.24 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for cookies BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_begonia.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] UFS: AD014839485131364145434D4D444152 UFS: VEN : 0x01AD VID : H9HQ16AECMMDAR IFW : A107 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : xxxxxxxxxxxx REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-12-01 Build Time : 07.01.2020 Product Model : Redmi Note 8 Pro Product Brand : Redmi Product Name : begonia Product Device : begonia Product Info : begonia Product Manfct : Xiaomi Product Board : begonia Board Platform : mt6785 NVRAM check : Failed! NVRAM damaged! NVRAM : SEC SIGNED [ IMEI RSA SIGNED ] Backup sensetive data [ 14 ] Backup path : Backup\MT6785__xxxxxxxxxxxxxxxxxxxxxxxx\ Backup done! STORAGE : LifeStatus : UFS : OK! PRELOADER : DEVICE : DEV : MT6752 NME : preloader_begonia.bin CNT : 000A EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : H9HQ53ACPMMDAR : RAM : [ 4,00 GB ] EMI : [02] : eUFS : LP_DDR4X : DEV : H9HQ53AECMMDAR : RAM : [ 6,00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : KM5H7001DM-B424 : RAM : [ 4,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM2H7001CM-B518 : RAM : [ 6,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : MT064GASAO2U21 : RAM : [ 4,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ21AFAMZDAR : RAM : [ 8,00 GB ] Done! Elapsed: 00:00:29 |
The Following 7 Users Say Thank You to JayDi For This Useful Post: |
