09-09-2015, 21:01 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | HSL S101 & GOODVE MOBILE S101 Both Are Same Cellphone, For More Info Check Inside HSL S101 & GOODVE MOBILE S101 Both Are Same Cellphone, You Can Convert Each Other, You Can Use Factory Firmware Each Other. I Converted From GOODVE MOBILE S101 To HSL S101 Operation : Check/Read Info [ v1.04 ] Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Read FullFlash [ v1.04 ] Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : GOODVE MOBILE Model Name : S101 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32__GOODVE MOBILE-S101.bin Done! Elapsed: 00:01:10 Reconnect Power/Cable! Operation : Read NV [ v1.04 ] Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data ... Reading NV ... Saved to : C:\InfinityBox\CM2SPD\phdata\backup\6531_NV_00008000.nv Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Check/Read Info [ v1.04 ] Code: Normal Normal , 1 : Power On phone. Insert USB cable ( Normal USB cable ) Service Service , 1 : Insert USB cable ( Use adapter or special cable ) Service , 2 : Insert battery Service , 3 : If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... Normal Mode init Sync... Phone Initial Info : Platform : MOCOR_12C.W13.04.22_Release ExtInfo : LCD(GC9101)CAM(SP0829)FM(SPRD_V0)BT(1)VIB(1) Compile : 07-23-2014 16:37:47 Phone Security Info : IMEI [1] : 352273017386340 IMEI [2] : 352751019523267 BT_ADDR : 000000000000 Done Reconnect Power/Cable! ---------------------------*** After Flash With HSL S101 Log ***----------------------------- Operation : Check/Read Info [ v1.04 ] Code: Normal Normal , 1 : Power On phone. Insert USB cable ( Normal USB cable ) Service Service , 1 : Insert USB cable ( Use adapter or special cable ) Service , 2 : Insert battery Service , 3 : If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... Normal Mode init Sync... Phone Initial Info : Platform : MOCOR_12C.W13.04.22_Release ExtInfo : LCD()CAM()FM(SPRD_V0)BT(1)VIB(1) Compile : 07-26-2014 17:41:26 Phone Security Info : IMEI [1] : 352273017386340 IMEI [2] : 352751019523267 BT_ADDR : 000000000000 Done Reconnect Power/Cable! Operation : Read FullFlash [ v1.04 ] Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 OM3:Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Ý* Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : HSL Model Name : S101 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32__HSL-S101.bin Done! Elapsed: 00:01:36 Reconnect Power/Cable! Operation : Repair Security [ v1.04 ] Code: Normal Normal , 1 : Power On phone. Insert USB cable ( Normal USB cable ) Service Service , 1 : Insert USB cable ( Use adapter or special cable ) Service , 2 : Insert battery Service , 3 : If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... Normal Mode init Sync... Phone Initial Info : Platform : MOCOR_12C.W13.04.22_Release ExtInfo : LCD()CAM()FM(SPRD_V0)BT(1)VIB(1) Compile : 07-26-2014 17:41:26 Phone Security Info : IMEI [1] : 352273017386340 IMEI [2] : 352751019523267 BT_ADDR : 000000000000 Read Ok! Write new security data : IMEI1 : 91134XXXXXXXXXX IMEI2 : 91134XXXXXXXXXX Write done! Elapsed: 00:00:04 Reconnect Power/Cable! |
