05-05-2016, 06:09 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | htc desire 326g flashing error now try with infinity box process-latest ver/fully charged bettry/full flash erase with infinity but no luck Code: Chinese Miracle II [SPD module] v 1.17 Loading : 2PNTIMG_V01A_DUG_K443_SENSE53_INDIA_1.51.720.1_RADIO_W15.15_V01A.WG.N06.W10.G10_RELEASE.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7730_UMS PacVersion : 2PNTIMG_V01A_DUG_K443_SENSE53_INDIA_1.51.720.1_RADIO_W15.15_V01A.WG.N06.W10.G10_RELEASE FastCheck : 0x0057E053A4 Loading files ... File : fdl1.bin.signed File : fdl2.bin.signed File : wnvitem.bin File : u-boot-spl-16k.bin.signed File : wmodem.bin.signed File : wdsp.bin.signed File : boot.img.signed File : recovery.img.signed File : system.img File : userdata.img File : bootlogo.bmp File : fbootlogo.bmp File : prodnv.img File : cache.img File : cota.img File : u-boot.bin.signed File : SC7730_UMS_sec.xml Load Ok! Operation : Flash Erase [ v1.17 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Flash Erase [ v1.17 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Flash Erase [ v1.17 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Erasig flash now, please wait ... Format finished! Reflash phone with normal FW now! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Flash [ v1.17 ] ======= Flash Files set for flashing : [ MCU ] : 2PNTIMG_V01A_DUG_K443_SENSE53_INDIA_1.51.720.1_RADIO_W15.15_V01A.WG.N06.W10.G10_RELEASE.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7730_UMS PacVersion : 2PNTIMG_V01A_DUG_K443_SENSE53_INDIA_1.51.720.1_RADIO_W15.15_V01A.WG.N06.W10.G10_RELEASE File : fdl1.bin.signed File : fdl2.bin.signed File : wnvitem.bin File : u-boot-spl-16k.bin.signed File : wmodem.bin.signed File : wdsp.bin.signed File : boot.img.signed File : recovery.img.signed File : system.img File : userdata.img File : bootlogo.bmp File : fbootlogo.bmp File : prodnv.img File : cache.img File : cota.img File : u-boot.bin.signed 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x19 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin.signed Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : wmodem.bin.signed Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : wdsp.bin.signed Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img.signed Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img.signed Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Error with code 0x0002 Elapsed: 00:02:17 Reconnect Power/Cable! if file problem then need if any have share |
05-05-2016, 08:12 | #3 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Code: ==== Wait for phone... Phone found! [ 22 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:06 Reconnect Power/Cable! BUT BEFORE FLASH SET WAS WORKING FINE AFTER FLASH ERROR WHEN WRITING SYSTEM FILE HOW THIS POSSIBLE |
05-05-2016, 08:20 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Can you open phone and try rehot eMMC well? Little flux + 360-375c for a 40-60 seconds. If can - try make that and flash it again. I nt checked it schematics, but if there is separate DRAM also - rehot it well. |
