01-15-2011, 13:41 | #6 (permalink) |
Freak Poster Join Date: Dec 2006 Location: Georgia
Member: 405233 Status: Offline Thanks Meter: 16 | ==== [13.01.2011 16:51:22] ==== COM23 [VCP0] selected module v3.72 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 chip: 0011:45B3:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C204SP03S Version: L75_HW 80 byte(s) read imei: connection Ok 185 byte(s) read reading data... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 16 sec Remove/Install battery now ! |
01-15-2011, 13:43 | #7 (permalink) |
Member: 405233 Status: Offline Thanks Meter: 16 | ==== [13.01.2011 16:40:21] ==== COM23 [VCP0] selected module v3.72 Device: Huawei-G3610 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 chip: 0011:45B3:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: G3610GEORGIA_PCB01_GPRS_MT6223P_S00.G3610_V100R001 B001C204SP03S.BIN project-id: G3610_V100R001B001C204SP03S, 00000000 code offset: 00000000 ffs offset/size [01]: 00A00000/00600000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00A00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... ............................ lock area found ............................ lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................... required data found flash: 2088C4FFFF0043:2088C400000000 flash: 2088C4FFFF0043:2088C400000000 Write: area 1 (pass 1) required data found flash: 2088C4FFFF0043:2088C400000000 flash: 2088C4FFFF0043:2088C400000000 Write: area 1 (pass 2) ..................... required data found flash: 2088C4FFFF0043:2088C400000000 flash: 2088C4FFFF0043:2088C400000000 Write: area 1 (pass 3) ....................... area 1 patch applied Ok Special operation Done ====> Write ... flash: 2088C4FFFF0043:2088C400000000 flash: 2088C4FFFF0043:2088C400000000 Write: lock-area-1 flash: 2088C4FFFF0043:2088C400000000 flash: 2088C4FFFF0043:2088C400000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 37 sec Remove/Install battery now ! |
01-16-2011, 21:17 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try to flash your phone: flashfiles/Huawei/G3610/Huawei-G3610_G3610GEORGIA_PCB01_GPRS_MT6223P_S00.G3610_V1 00R001B001C204SP03S_2010-11-22_En_Ru_Geocell-Georgia.B0M.bin |
02-13-2011, 10:40 | #12 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @achi_nokia Try to unlock this phone with latest MModule v3.74 Use "read unlock codes" unlock method. What is the results ? |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
02-13-2011, 20:00 | #13 (permalink) |
Member: 405233 Status: Offline Thanks Meter: 16 | I will try in few days and I will write results thanks ''YellowBoss'' and infinity team |
The Following User Says Thank You to achi_nokia For This Useful Post: |
02-21-2011, 10:22 | #14 (permalink) |
Member: 405233 Status: Offline Thanks Meter: 16 | Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 chip: 0011:45B3:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C204SP03S Version: L75_HW 80 byte(s) read imei: connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + 12345678 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 30 sec Remove/Install battery now ! and how to enter codes? when another network's sim card inserted phone says wrong sim card inserted |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
