05-11-2011, 16:52 | #1 (permalink) |
Insane Poster Join Date: Oct 2008
Member: 885074 Status: Offline Thanks Meter: 4 | huawei g6600 np code probleme COM59 [VCP0] selected module v3.73 Action: read unlock codes unlock method: read codes Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2FY01V01.09 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35751003921134 connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 Finished, time used: 16 sec Remove/Install battery now ! user/lock code COM59 [VCP0] selected module v3.73 Action: read unlock codes unlock method: read codes Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2FY01V01.09 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35751003921134 connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 Finished, time used: 16 sec Remove/Install battery now ! detailed information COM59 [VCP0] selected module v3.73 Device: Huawei-G6600 Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0056]: 0020:003600200036 [ST] ST512R3A chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E5.2FY01V01.09 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: BYD35_09A_PMWY_BOOTLOADER_V005_MT6235B_E5_2FY01V01 _09.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: BYD35_09A_PMWY_PCB01_GPRS_MT6235B_S01.E5_2FY01V01_ 09.BIN project-id: E5.2FY01V01.09, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done Disconnect... done Finished, time used: 45 sec Remove/Install battery now ! tel demend code np with sim |
05-12-2011, 09:02 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | I strongly suggest you download and install latest Infinity-Box updates. Do not use half year old software !!! |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
