07-27-2010, 14:38 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Nador-Morocco Age: 38
Member: 694713 Status: Offline Thanks Meter: 92 | Huawei-G7007 Dead After flash [HELP PLS] Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: ENGC27B162 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC27B162.bi n warning: id-page1 area is invalid nfi area detection finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC27B162.BIN project-id: ENGC27B162, 01D1CE58 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [protected] type, 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC27B162.bi n nfi area detection finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... error: can not write flash: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC27B1 62__system_log_20100727-133057.B4X.bin Finished, time used: 5 min 8 sec Remove/Install battery now ! Pls How to repair this problame !!!!! |
The Following User Says Thank You to OpssPhone For This Useful Post: |
09-08-2010, 08:12 | #8 (permalink) |
Freak Poster Join Date: Dec 2005 Location: uk
Member: 211830 Status: Offline Thanks Meter: 13 | i have same problem with this kpn nederlands phone i flashed with infinity from support but now only startup phone and blinking please infinity team help us. BR |
The Following User Says Thank You to karwanyhata For This Useful Post: |
09-08-2010, 11:41 | #9 (permalink) | |
Why you post other information in other thread ? http://forum.gsmhosting.com/vbb/f296...9/#post6306249 so, where is the truth ? | |
09-13-2010, 21:12 | #11 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 593061 Status: Offline Thanks Meter: 19 | I have a phone with "error 23" i have flash the phone with firmware from support but the same problem "error 23" Code: COM6 [VCP0] selected module v3.59 Device: Huawei-G7007 Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC27B162_Ver.B_Apr-27-2010_En_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC27B162.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: ENGC27B162 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC27B162.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC27B162.BIN project-id: ENGC27B162, 01D1CE58 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: HUAWEI35_08B_BOOTLOADER_V005_MT6235B_ENGC27B162.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Huawei-G7007_HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC27B162__system_log_20100913-153215.B4X.bin Finished, time used: 7 min 16 sec Remove/Install battery now ! Code: Action: read/check information Model: Huawei-G7007 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: VER.B Software version: ENGC27B162" Software date: 2000.00.00 Barcode: MT012345678901234567 imei-1: 863349000146701 Finished, time used: 2 sec Remove/Install battery now ! |
