09-13-2012, 10:13 | #2 (permalink) |
Insane Poster Join Date: Jul 2005 Age: 41
Member: 164466 Status: Offline Thanks Meter: 4 | COM60 [Serial2] selected module v4.38 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Huawei-G7300_BYD36_10A_PCB01_GPRS_MT6236_S00.U5_6PY01V01_ 05_2011-09-15_En_Pt.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6236:8A02:8A00]... CPU: MT6236 high speed boot On chip: 0000:0000:0000 status: FF error: can't set initial baud Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 6 sec Remove/Install battery now ! |
09-13-2012, 10:32 | #3 (permalink) |
Member: 164466 Status: Offline Thanks Meter: 4 | COM60 [Serial2] selected module v4.38 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7300_BYD36_10A_PCB01_GPRS_MT6236_S00.U5_6PY01V01_ 05_2011-09-15_En_Pt.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... incorrect ext bootloader signature: 10B501F0 bootloader version: BYD36_10A_BOOTLOADER_V005_MT6236_U5_6PY01V01_05.bi n nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6236:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0055]: 0098:00B100900055 [TOSHIBA] TC58NYG0S8C chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00018000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6236:8A02:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: U5.6PY01V01.05 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: BYD36_10A_PCB01_GPRS_MT6236_S00.U5_6PY01V01_05.BIN project-id: U5.6PY01V01.05, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... incorrect ext bootloader signature: 10B501F0 bootloader version: BYD36_10A_BOOTLOADER_V005_MT6236_U5_6PY01V01_05.bi n nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . write core... ok done ! but not power on |
