12-22-2016, 07:52 | #1 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Ph
Member: 2348059 Status: Offline Sonork: 100.293844 Thanks Meter: 45 | huawei tag l22 frp Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00: Reconnect Power/Cable! FRP GOOGLE ACCOUNT HELP ME |
12-22-2016, 12:05 | #3 (permalink) |
Member: 2348059 Status: Offline Sonork: 100.293844 Thanks Meter: 45 | BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A0190653247418022070533269824 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2008 DA_LOAD_FAILED Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! |
12-22-2016, 12:10 | #4 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: Kushtia,Bangladesh Age: 36
Member: 1217358 Status: Offline Sonork: 100.1605541 Thanks Meter: 156 | Quote:
06-23-2017, 11:18 | #6 (permalink) |
Member: 2348059 Status: Offline Sonork: 100.293844 Thanks Meter: 45 | Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A0190653247418022070533269824 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2008 DA_LOAD_FAILED Boot Error! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! phone dead again |
07-02-2017, 06:38 | #8 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Ilam,Nepal
Member: 2378764 Status: Offline Sonork: I Dont Use !!! Thanks Meter: 60 | i am not a infinity user but i can help you with different tools and its worked 100% sure !!! |
The Following User Says Thank You to saenchep For This Useful Post: |
