09-07-2016, 12:07 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | HUAWEI Y336-U02 firmware read done . 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Passed! Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : Y336-U02 Model Brand : HUAWEI Model Device: HWY336-U AndrVersion : 4.4.2 BaseBand CPU: Y336-U02 Project Ver : Y336-U02V100R001C567B113 Model Ext : HUAWEI Y336-U02 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : dlstat.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : sysinfo.bin [Read Ok] : custom.bin [Read Ok] : globalinfo.bin [Read Ok] : userdata.img AndroidInfo created Firmware Size : 1400 MiB Saved to : C:\Users\mobile\Desktop\Y336-U02_HWY336-U_4.4.2_Y336-U02V100R001C567B113_HUAWEI_Y336-U02\ Done! Elapsed: 00:20:48 Reconnect Power/Cable! Finish at : [9/7/2016 / 4:02:22 AM] |
The Following 4 Users Say Thank You to malka4u For This Useful Post: |
09-08-2016, 04:54 | #2 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | convert to pac file done . -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Chinese Miracle II [SPD module] v 1.21 Operation : Convert InfinitySC to SPRD PAC [ v1.21 ] Target : Y336-U02 V100R001C567B113 Step #1 : Identify MEMORY : eMMC LAYOUT : eMMC NORMAL Rebuild data required ... Rebuild Ok! Rebuild data required ... Rebuild Ok! Step #2 : Select logic Select Logic : SC7731 Step #3 : Processing data Build PAC [ADD FILE] : nvitem_w.bin [ADD FILE] : prodnv.img [ADD FILE] : u-boot-spl-16k.bin [ADD FILE] : sc7731g_CP0_modem.bin [ADD FILE] : DSP_DM_Gx.bin [ADD FILE] : logo_480x800.bin [ADD FILE] : fblogo_480x800.bin [ADD FILE] : boot.img [ADD FILE] : system.img [ADD FILE] : cache.img [ADD FILE] : recovery.img [ADD FILE] : userdata.img [ADD FILE] : u-boot.bin Build Ok! Result : 0x0014 Sign PAC ... Sign Ok! FW compiled! Elapsed: 00:04:14 Saved to : Y336-U02 V100R001C567B113.pac Done! |
09-08-2016, 06:08 | #4 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | |
The Following 3 Users Say Thank You to mbiborna For This Useful Post: |
09-24-2016, 07:00 | #5 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | but same file flash error need help Operation : Flash [ v1.21 ] ======= Flash Files set for flashing : [ MCU ] : Y336-U02 V100R001C567B113.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : SC7731_eMMC_Y336-U02 V100R001C567B11_INFINITY-BOX File : Infinity_fdl1.bin File : Infinity_fdl2.bin File : nvitem_w.bin File : prodnv.img File : u-boot-spl-16k.bin File : sc7731g_CP0_modem.bin File : DSP_DM_Gx.bin File : logo_480x800.bin File : fblogo_480x800.bin File : boot.img File : system.img File : cache.img File : recovery.img File : userdata.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x16 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : sc7731g_CP0_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_Gx.bin Flashing now ... [FlashProc] : Error with code 0x0001 Elapsed: 00:02:27 Reconnect Power/Cable! Finish at : [9/23/2016 / 10:58:09 PM] |
The Following User Says Thank You to malka4u For This Useful Post: |
01-24-2017, 07:04 | #9 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | |
01-24-2017, 07:12 | #10 (permalink) |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | download this update Needrom | No Login Step one: Prepare an SD card, it is recommended to use Sandisk, Kingstone, or Kingmax, size is recommended that more than 1G. Step Two: Formatting SD card (optional). The step three: copy a large package path UPDATA.APP to the SD card dload UPDATA.APP. Step four: Check the root directory of the SD card you dload UPDATA.APP. Step 5: SD card into the phone is switched on in the main screen, press the Menu key, the system updates -> SD card upgrade -> confirm -> upgrade, backup data, select the backup data; upgrade. Step Six: The upgrade process progress bar shows after the finish of the pending progress bar, the phone automatically restart. or Step one: Prepare an SD card, it is recommended to use Sandisk, Kingstone, or Kingmax, size is recommended that more than 1G. Step Two: Formatting SD card (optional). The step three: copy a large package path UPDATA.APP to the SD card dload UPDATA.APP. Step four: Check the root directory of the SD card you dload UPDATA.APP. Step Four: cell phone turned off, insert the SD card, while pressing the volume up button + volume down key switch button, the phone automatically enters the upgrade mode, and then begin the upgrade in Figure Step Five: After the progress bar to go full fixed, the phone will automatically restart If you do not manually remove the battery. |
The Following User Says Thank You to appsworlmardan For This Useful Post: |
11-30-2018, 06:41 | #14 (permalink) | |
Insane Poster Join Date: Nov 2015 Location: Nigeria
Member: 2491104 Status: Offline Thanks Meter: 15 | pls share me Quote:
