02-24-2020, 11:02 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Algeria Age: 54
Member: 144511 Status: Offline Thanks Meter: 13 | huawei y5-2 cun-l01 frp error Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.07 Load IDBase v124106 Ok! Operation : Reset Settings/Format FS [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM122) MODE : PRELOADER PORT PORT : 122 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM122) MODE : PRELOADER PORT PORT : 122 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Huawei : Y5II [ CUN-Lxx ] | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464E31324D42062648A79FE7AF DAInf: 4 : 2 : 147 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E31324D42062648A79F83AF EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN12MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00080000 [ 512,00 KB ] USER : 0x1D2000000 [ 7,28 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6452DDD1D50C73644B227D8C6CF84C87 STATUS : DA : NOR OTP GETSIZE FAIL BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! Last edited by NewMobicool; 02-24-2020 at 11:09. |
02-24-2020, 12:55 | #2 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1050365 Status: Offline Thanks Meter: 210 | Change Global Settings PRT MODE[ Default] to ADR Mode [ Extended]. Init MemoryTool. Wipe FRP partition. |
The Following User Says Thank You to Bimal Shah For This Useful Post: |
