01-29-2009, 09:36 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Sri Lanka , Kandy Age: 34
Member: 763865 Status: Offline Sonork: Cvlvertcharges Thanks Meter: 123 | Huwawi T261 unlock succesfull module v1.61 Device: Huawei-T201 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T201_eeprom-static_20090129-135323.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T201_eeprom-security_20090129-135324.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T201_eeprom-complete_20090129-135325.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T201_lock-area_20090129-135328.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 23 sec Remove/Install battery now ! |
The Following User Says Thank You to a.w.m.wafaz For This Useful Post: |
01-29-2009, 10:50 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
wow unlockers n96 unlock succesfull without credit... | chohansahib | Cyclonebox | 1 | 07-18-2009 16:43 |
S853 unlock succesfull??? | selfbox | TSMbox+ | 10 | 03-31-2008 22:32 |
E-61 Rm-89 Unlock Succesfull Unlock | div_raj | J.A.F. V-SPEC | 0 | 03-03-2008 09:16 |
6233 Unlock Succesfull | Colin | MT-BOX | 0 | 09-19-2007 15:48 |
Log unlocking succesfull Moto C 261 | Unlocker AL | Infinity-Box | 6 | 01-08-2007 09:25 |
