04-12-2008, 10:00 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Antalya/Türkiye Age: 43
Member: 64224 Status: Offline Thanks Meter: 24 | i cant unlock sagem my150x loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported sw version: EAI_IC_300707_1408 300707_1408 EAI_IC Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080412-113541.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\za35_eep65535.cfg error: can't load database v.14 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080412-113544.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-113559.B1E.bin reading additional data... done backup critical area Done Check memory... error: unknown firmware, read flash and send to support ! Check memory Failed Finished, Remove/Install battery now ! i sent the back-up support can u check your mail |
04-12-2008, 10:09 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you have downloaded Pana01 software by direct link given in this forum before, please, download software again from Infinity-Box support area and try to make unlock again (software from suppoirt area has some improvements). If you have used software from support area we will check your backup file. |
04-12-2008, 10:31 | #4 (permalink) |
Member: 64224 Status: Offline Thanks Meter: 24 | i download 1.43 again and setup now unlocked thx infinity team Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.43 S/N: ***x:***x Wait... Current model: Coral-200 Ready Current model: Sagem-my150x COM4 [VCP0] selected Device: Sagem-my150x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported sw version: EAI_IC_300707_1408 300707_1408 EAI_IC Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080412-122807.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\za35_eep65535.cfg error: can't load database v.14 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080412-122817.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-122837.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 93 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
08-15-2008, 12:35 | #9 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
i unlonked my 150x but it still lock wats wrong with this set bcoz i already unlocked dozen of this model but this 1 not unlocked? | |
good unlock Sagem-my150x | tornado2008 | Infinity-Box | 1 | 05-06-2008 17:24 |
Unlock Sagem My150x ????? | multicom_fsdpk | Infinity-Box | 1 | 04-17-2008 19:08 |
unlock sagem my150x | faustus | ARM9 BASED M62 / M62+ | 1 | 12-30-2007 03:44 |
cant unlock Sagem | michaeo | Infineon C16X M51 & ARM7 M52 BASED | 0 | 10-17-2005 16:59 |
