05-05-2014, 02:03 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | I have many phones and sc6530 sc6531 for testing My first backup by Infinity Card found: S/N 1BC6:0126 Chinese Miracle II [SPD module] v 0.04 COM15 : Open port failed! Operation : Check/Read Info 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C2 0025 0038 0000 Flash VEN : Macronix , MX25 Flash CAP : 01000000 Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Read FullFlash 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash DIE : 00C2 0025 0038 0000 Flash VEN : Macronix , MX25 Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B_6531.W13.07_Debug F4_PMZ_128X64_272X480_L1 Project : F4_PMZ_128X64_272X480_L1_V02.01B12 HWInfo : F4_PMZ_128X64_272X480_L1_V02.01B12 Compile : 09-17-2013 12:15:26 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MO COR_12B_6531.W13.07_Debug F4_PMZ_128X64_272X480_L1_09172013121526.bin Done! Elapsed: 00:01:38 Reconnect Power/Cable! |
The Following User Says Thank You to turca For This Useful Post: |
05-05-2014, 03:34 | #2 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello! Yes, sure : Quote:
If you have locked to network phones : they also need, add to them "locked" string. Thanks for your help! | |
The Following User Says Thank You to Dzirt For This Useful Post: |
07-26-2014, 11:09 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | Qmobile 113 spd cpu sc6531 locked firmware from orange cameroon this is log can you give a solution? ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : Qmobile Model Name : Q113 ExtInfo Data : FRENCH Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD 25LQ32_FRENCH__Qmobile-Q113.bin Done! Elapsed: 00:02:34 Reconnect Power/Cable! |
