05-18-2010, 15:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | I-mobile 613 can't read Nor flash with cm not work read full flash Code: COM2 [VCP0] selected module v3.13 Device: Autodetect 6228-6229 NOR Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:2A01 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 number of flash chip/regions detected: 00/01 flash chip is unknown or damaged, operation aborted. Fault reasons: 1. unknown hardware: contact to support: [email protected] 2. hardware is damaged: check hardware, water inside etc. Initialize Fail Finished, time used: 11 sec Remove/Install battery now ! Code: COM2 [VCP0] selected module v3.13 Device: Autodetect 6228-6229 NOR Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:2A01 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 number of flash chip/regions detected: 00/01 flash chip is unknown or damaged, operation aborted. Fault reasons: 1. unknown hardware: contact to support: [email protected] 2. hardware is damaged: check hardware, water inside etc. Initialize Fail Finished, time used: 17 sec Remove/Install battery now ! Code: COM2 [VCP0] selected module v3.13 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6228:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0007]: 00EC:00F100000095 [SAMSUNG] K9F1G08X0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: MAUI.05C.W06.24.MP.V23 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: DARTS6228_05C_BOOTLOADER_V005_MT6228_MAUI_05C_W06_24_MP_V23.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: DARTS6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_MP_V23.BIN project-id: MAUI.05C.W06.24.MP.V23, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Users\AlaM\Desktop\I-mobile 613\DARTS6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_MP_V23__firmware_20100518-194301.B4M.bin Disconnect... done Finished, time used: 12 min 1 sec Remove/Install battery now ! |
The Following User Says Thank You to alamgir80 For This Useful Post: |
05-21-2010, 10:04 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Please, read NAND firmware from this phone and send file (or link) to [email protected] Also, what is this phone pinout ? |
05-21-2010, 13:02 | #3 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | Cable name: LG-C2500 keyboard top /12345\ 1: Gnd 3: box Rx/phone Tx/PinFinder Rx (RJ45 pin-3) 4: box Tx/phone Rx/PinFinder Tx (RJ45 pin-2) here file link RapidShare: 1-CLICK Web hosting - Easy Filehosting Last edited by alamgir80; 05-21-2010 at 13:07. |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
