Old 04-14-2009, 08:36   #1 (permalink)
Member: 71603
Thanks Meter: 31
I-Mobile 901 After flash Only White LCD
My I-mobile 901, some time hang and restart, i tryed format but it is the seme, so i backup and flash 4file from support site but phone only white LCD. try to flash with backup file get this error when load firmware.
Loading file v.02...
error: data error !
Loading failed, probably damaged data file.
Log flash with support file
COM4 [Serial2] selected
Device: I-Mobile-901
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6217:8A00]...
CPU: MT6217
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98001B00000009:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Area: Firmware
Write: Firmware
Write Done
Finalization...
formatting...
flash: 98001B00000009:18000000000000
Finalization Done
Finished, time used: 78 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
How to sloved my problem, pls?
Old 04-14-2009, 08:49   #2 (permalink)
Member: 71603
Thanks Meter: 31
Here my flash backup file: http://www.4shared.com/file/98454804...092731B0X.html
Old 04-14-2009, 10:02   #3 (permalink)
Member: 130995
Thanks Meter: 35,228
Hello,
Flash phone with this file from support area: IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-000-00_En_Th.B0M.bin
Your phone has the same version.
Old 04-14-2009, 11:14   #4 (permalink)
Member: 71603
Thanks Meter: 31
Thanks for Ur reply, before post I tryed flash 4 files from support site, but only white LCD:
IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-28-2006_901P64-66-V10z-000-00-JUN-27-2006_En_Th.B0M
IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-28-2006_901P64-66-V10z-XXX-XX-JUN-27-2006_En_Th.B0M
IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-XXX-XX_En_Th.B0M
Old 04-14-2009, 18:07   #5 (permalink)
Member: 130995
Hello,
1. Flash phone with this file from support area: IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-000-00_En_Th.B0M.bin
2. Try to use two repair eeprom files one by one.
Old 04-15-2009, 10:13   #6 (permalink)
Member: 71603
Thanks Meter: 31
Flash with file name: IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-000-00_En_Th.B0M.bin phone still white LCD only,
Tryed eeprom file: IMobile-901_repair_eeprom_01.B0E or IMobile-901_repair_eeprom_02.B0E it is the same.
How can i do, pls?
Old 04-17-2009, 12:17   #7 (permalink)
Member: 130995
Hello,
I suggest you to check phone hardware due to IMobile-901_MADDRTATH0TP7B50D_MADRID_HW_B4_Jun-30-2006_901P64-66-V10z-000-00_En_Th.B0M.bin + IMobile-901_repair_eeprom_02.B0E is your original phone backup.
If after flash with these files your phone still can not work well there is a reason to check phone hardware.
need help wu800i after flashing only white blink /\/\A/\/| Sony Ericsson 11 08-03-2009 21:01
E200 after flash only white screen!!help dominik1 NSPRO 5 11-28-2008 17:17
sigmatel s1 after flash only white screen? akt007 SpiderMan 1 11-13-2008 14:03
Page generated in 0.21585 seconds with 9 queries
