05-11-2011, 14:13 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 364992 Status: Offline Thanks Meter: 28 | i766 dead time: new phone, read fullflash and send to us... but i when flashed phone, i didnt do backup... i think in log original flashfile was i766 AFFA112 claro argentina. and in support is AFFA111.... how can i revive this phone? all the time software says if i want to continue but phone will cant power on... :confuse d |
05-13-2011, 22:53 | #4 (permalink) |
Member: 364992 Status: Offline Thanks Meter: 28 | first i flash with this.. then phone dead.. and tried with others in support and same error.,. Code: [06/05/2011 05:40:03 p.m.] ==== COM2 [VCP0] selected module v3.83 Device: ZTE-i766 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware ZTE-i766_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA111_Claro-Argentina_En_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:5303:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\InfinityBox\MModule\backup_security\id.E0C2DC6A.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA112.BIN_B8E1606D].rpl ==================== New firmware found (v.3.83, database date: 25.04.2011): ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA112.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: E0C2DC6A rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA112.BIN project-id: i766_V2_Z6_S_AFFA112, 6D60E1B8 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\InfinityBox\MModule\id.E0C2DC6A.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA111.BIN_E19C2D5D].rpl rpl file not found: C:\InfinityBox\MModule\id.E0C2DC6A._ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA111.BIN_E19C2D5D_.rpl rpl file not found: C:\InfinityBox\MModule\backup_security\id.E0C2DC6A.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA111.BIN_E19C2D5D].rpl rpl file not found: C:\InfinityBox\MModule\backup_security\id.E0C2DC6A._ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA111.BIN_E19C2D5D_.rpl ==================== warning: unknown firmware: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA111.BIN_E19C2D5D Unknown firmware found (v.3.83, database date: 25.04.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA111.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? file saved: C:\InfinityBox\MModule\backup_security\ZTE-i766_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.I766_V2_Z6_S_AFFA112__system_log_E0C2DC6A_B8E1606D_20110506-174059.B0X.bin Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
