11-16-2015, 16:42 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | iBallSlide.6351Q40i mt 8127 suppoted... ? Code: Card found : S/N : , v0129 Chinese Miracle II [MTK module] v 1.37 Unsupported Yet( or bad ) file selected! Start at : [11/16/2015 / 9:01:41 PM] Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 8127 BB_CPU_HW : CA04 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT8127_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 004500DE009400930076005000080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8D DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x004D , [MNAND] mNAND [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! write flash so.. ( og flashfile ) Code: Chinese Miracle II [MTK module] v 1.37 Unsupported Yet( or bad ) file selected! thanks advance |
11-17-2015, 13:41 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Sure, flashing will help. Will continue seek for more Tablet with NAND CPU on MTK. |
