04-25-2023, 02:29 | #32 (permalink) |
Insane Poster Join Date: Apr 2019 Location: Toamasina Madagascar
Member: 2903727 Status: Offline Thanks Meter: 22 | Itel S661W app not found Operation: [ADB] Uninstall Apps Loading... File: C:\InfinityBox\AST\files\1.txt Apps List: com.scorpio.securitycom [/product/app/SecurityCom/SecurityCom] Wait... 1. Power device On 2. Be sure [DEVELOPER MODE] and [USB DEBUG] are On 3. Connect USB cable 4. Accept AUTH on phone screen Waiting for device [ADB mode]... Connect Ok Wait... Reading... Serial: 0123456789ABCDEF Model: itel S661W Process... Uninstall com.scorpio.securitycom [/product/app/SecurityCom/SecurityCom]... Not found NOTE: Deleted application will be restored back in case of WIPE! Done: 00:00:29 I have Itel S661W and I want to remove this security plugin but app not found. I checked this app and it's listed in the text file. I test all other apps OK and removed but this No |
04-25-2023, 02:40 | #33 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: Argentina
Member: 1050909 Status: Offline Thanks Meter: 39 | Quote:
04-25-2023, 12:49 | #34 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,993 | Quote:
04-25-2023, 13:41 | #35 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Pakistan
Member: 2241683 Status: Offline Thanks Meter: 11 | Problem Updating Card Firmware... when I update my Card this comes UP === DongleManager [Infinity] v1.94 [4/25/2023 5:40:26 PM] === Box/Dongle type selected: Infinity [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0100AE7808B51292 Box/Dongle found: Infinity [BEST] Reading... Serial No (S/N): 9CCEAE78 Firmware version: 0122.02 === Started: 4/25/2023 5:40:26 PM === Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0007] No update available Why? 1.Smart-Card has latest firmware version. Update is not required. OR 2.Support period is expired, check it here - https://infinity-box.com/doc/?r=17 If support expired contact to any seller and renew - https://infinity-box.com/buy/ |
04-27-2023, 01:15 | #36 (permalink) | |
No Life Poster Join Date: Mar 2016 Location: IN THE KERNEL
Member: 2545468 Status: Offline Thanks Meter: 235 | hi i'm a little confused Quote:
04-27-2023, 23:43 | #37 (permalink) | |
Your dongle support period is expired 2020-Jul-01 Send your dongle S/N to any seller and oder [CM2] support renew for 1 or 2 years Sellers - https://infinity-box.com/buy/ How to check support date - https://infinity-box.com/doc/?r=17 | |
04-27-2023, 23:44 | #38 (permalink) | |
Do you see fault.bin file in folder with software? | |
04-30-2023, 17:13 | #40 (permalink) |
Junior Member Join Date: May 2022 Location: egypt
Member: 3013589 Status: Offline Thanks Meter: 1 | it's helpfull tool, i use it to reboot from fastboot but when i read info fastboot the result is not understandable i couldn't find device model or firmware easy |
06-12-2023, 11:56 | #43 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,993 | Infinity Android Service Tool #AST v1.06 - startup process and external dll's handling method revised - external dll's moved to /lib/ - external dll's verification method updated - packed firmware files handling updated - remote files verification method changed - separate fscard.ini file is not required any more - auto-update check method changed to once per day - minor ui changes - many internal changes and improvements |
The Following 4 Users Say Thank You to YellowBoss For This Useful Post: |
08-30-2023, 11:05 | #44 (permalink) | |
Insane Poster Join Date: May 2009 Location: india
Member: 1035639 Status: Offline Thanks Meter: 5 | can i use old version of AST 1.03 (only CDMA Tool Activate on my card) Quote:
Code: === DongleManager [Infinity] v1.94 [30-08-2023 03:33:03 PM] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0002D9F30000**** Box/Dongle found: Infinity CDMA-Tool Serial No (S/N): 0******* Firmware version: 0122.02 "UK Edition" status: On Last launched Application: 0000 v.0000 => Activations: - 01: Infinity CDMA-Tool v0122 => Options: - Infinity CDMA | |
08-31-2023, 10:16 | #45 (permalink) | |
CDMA is for CDMA only. But you can add CM2/Infinity-Box/Dongle to your CDMA Dongle | |
