Old 07-27-2017, 07:04   #1 (permalink)
Member: 148515
Thanks Meter: 19,534
Infinity-Box Android Service Tool / AST v1.01 - first update
Fastboot tab activated:
- Identify / Read device info
- Reset FRP ( MTK, SPRD, QLM mode )
- Change mode ( Normal, Bootloader, Recovery, EDL )
Motorola:
- Improved Flashing engine
In case of downgrade SW will ask about force flashing ( if bootloader unlocked )
Improved flashing : timeout fixes for big blocks
Improved flashing : revised flash pre-verification
Improved flashing : FW check and verify revised
- Enabled Bootloader operations
Get Unlock token - get data for Motorola boot unlock ( via MotoUnlockDev support )
Send unlock token - apply boot unlock code to device ( just copy received code in buffer )
- Improved ADB enable function
- Improved Reset FRP function
Other
FastBoot/ADB protocols revised
Some main core changes and bugfixes
Download link
Upload file to Support - Download files via Torrent
Infinity-Box 12 years (2005 - 2017) updates and support as nobody else - News
Twitter - Facebook - Telegram
The Following 68 Users Say Thank You to InfinityHelp For This Useful Post:
Old 07-27-2017, 13:41   #2 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 440
please support Moto XT1643 july patch, frp not sucess
The Following 2 Users Say Thank You to avtarkaint For This Useful Post:
Old 07-29-2017, 07:16   #3 (permalink)
Member: 1220104
Sonork: 1592061
Thanks Meter: 44
my Main Infinity-Box/Dongle Update Problem Please Help ..
=== DongleManager [Infinity] v1.70 [7/29/2017 12:13:01] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 00032947FF021982
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 35C02947
Firmware version: 0112.02
=== Process started: 7/29/2017 12:13:05 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0006] Your account is temporary suspended.
See problem reason in log file
Contact to http://www.infinity-box.com/support/?r=2
Old 07-29-2017, 14:48   #4 (permalink)
abdul.majid8186's Avatar
Member: 2582370
Sonork: 100.1675531
Thanks Meter: 126
Please Help
Try To change Ip Adress..Please Solve This Problem
Old 07-29-2017, 14:49   #5 (permalink)
Member: 2582370
Sonork: 100.1675531
Thanks Meter: 126
Please Help
Xt1096 Not Enable ADB
Old 07-29-2017, 14:53   #6 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Moto X play Hanging Problem Solved By AST TooL
Read Info.............
Infinity-Box Android Service Tool [AST] v1.01
Operation : Identify [ v1.01 ]
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Main Info ============
CPU : MSM8939
CID : 0x0007
IMEI : 358953064167552
UID : 9096AC0500000000000000000000
Model Info ============
DevModel : XT1562
IntName : lux
SW Info ============
DevSWVer : Blur_Version.24.201.5.lux_retasia_ds.retasiaall.en .03
DevQCVer : AU_LINUX_ANDROID_LA.BR.1.1.3_RB1.05.01.00.032.015
BaseBand : M8936_2020632.44.03.21.57R LUX_EMEA_DSDS_CUST
BootLDRv : moto-msm8939-80.EF
HW Info ============
eMMCInfo : 16GB Toshiba REV=07 PRV=00 TYPE=57
DRAMInfo : 2048MB Hynix S8 SDRAM DIE=8Gb
Lock Info ============
BLUnlock : no
WarrantyVoid : no
FRP Lock : no protection (0)
Done!
Elapsed: 00:00:18
Factory Reset
Operation : Reset Settings [ v1.01 ]
Mode : Format FS
Connect Ok!
Block [1] ERASE OK!
Block [2] ERASE OK!
Done!
Elapsed: 00:00:09
The Following 3 Users Say Thank You to 4G Telecom For This Useful Post:
Old 07-30-2017, 07:35   #7 (permalink)
Member: 1681098
Sonork: mahindra
Thanks Meter: 74
world best updates & 100% success thanks to infinity team for support
The Following User Says Thank You to irfan2582 For This Useful Post:
Old 08-01-2017, 12:43   #8 (permalink)
Member: 29155
Thanks Meter: 15
AST runs with error msg "Dongle firmware version is outdate".
But Dongle manager says "No updates found for your Smart-Card. DO NOT try more today !".
Is this update not for me ?
=== DongleManager [Infinity] v1.70 [01.08.2017 15:40:29] ===
HWID: 00014938Fxxxxxx
Reading...
Serial No (S/N): CD9xxxxx
Firmware version: 0128.02
=== Process started: 01.08.2017 15:40:32 ===
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
The Following User Says Thank You to Jiminay2000 For This Useful Post:
Old 08-01-2017, 14:58   #9 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Reading...
Hello,
What is your support Expiry date? HERE is instruction how to check.
If your support has expired contact any Reseller or ME to renew support.
Br.
Infinity Box Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 08-01-2017, 15:39   #10 (permalink)
Member: 18234
Thanks Meter: 97
Operation : Reset FRP (ADB) [ v1.01 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : lux_retasia_ds
Model : XT1562
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:13
The Following 2 Users Say Thank You to nafanya For This Useful Post:
Old 08-01-2017, 18:48   #11 (permalink)
Member: 2088434
Sonork: 100.1659449
Thanks Meter: 52
Goto disconnect your internet connection. After your problem solve
Old 08-02-2017, 06:36   #12 (permalink)
r4raja007's Avatar
Member: 1503356
Thanks Meter: 110
hello sir tell it working old infinity non activation only smart cart update
The Following User Says Thank You to r4raja007 For This Useful Post:
Old 08-02-2017, 06:38   #13 (permalink)
Member: 1726688
Thanks Meter: 9
Motorola:
Other
Download link
Old 08-02-2017, 09:21   #14 (permalink)
Member: 29155
Thanks Meter: 15
I go to https://user.infinity-box.com/index.php
Input username and password from donglemanager
But get Wrong Username or Password
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
Infinity Box Team.
Old 08-02-2017, 22:52   #15 (permalink)
Member: 2703335
Thanks Meter: 22
I i have cm2 dongle! Can i use this tool?
The Following User Says Thank You to MedjoHost For This Useful Post:
Page generated in 0.28059 seconds with 9 queries
