08-03-2017, 06:37 | #31 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Russia norten-caucasus Age: 52
Member: 18234 Status: Offline Thanks Meter: 97 | |
The Following User Says Thank You to nafanya For This Useful Post: |
08-03-2017, 06:39 | #32 (permalink) | |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | ohh thanks sir for it Quote:
STEP 1 (Connect): Open "Android ADB" platform in the tab menu in the upper left side of the software Open "Qualcomm" bookmark Set the phone to the FACTORY MODE: Turn the phone OFF Press Vol -, Vol+, Power ON simultaneously, then release Power ON button Select FACTORY MODE in the appeared menu, then confirm your selection Wait for the phone to fully power ON Connect the phone to PC using USB cable Install required USB Driver (only if phone is connected for the first time) Press "Connect Motorola Android phone" Wait for the operation to complete and disconnect the phone STEP 2 (Reset FRP): Set the phone to the FACTORY MODE: Turn the phone OFF Press Vol -, Vol+, Power ON simultaneously, then release Power ON button Select FACTORY MODE in the appeared menu, then confirm your selection Wait for the phone to fully power ON and connect it to PC Select "Adb interface" in the port selection tab Press "Remove FRP" button Message "Done" indicates that the procedure has been completed successfully Restart the phone We recommend performing master reset from the phone’s menu after completing the remove FRP operation. | |
The Following 2 Users Say Thank You to pintu_das For This Useful Post: |
08-03-2017, 12:48 | #41 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Hello Download here Index of pub/software/ You can use when you activated CM2 on your BEST DONGLE. Price here https://www.infinity-box.com/price.php Last edited by Kirumira; 08-03-2017 at 12:55. |
08-03-2017, 14:17 | #44 (permalink) |
Freak Poster Join Date: Feb 2005 Location: egypt
Member: 119435 Status: Offline Thanks Meter: 52 | Moto Z Play Reset FRP done Operation : Reset FRP (ADB) [ v1.01 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : addison Model : XT1635-02 FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:12 |
The Following User Says Thank You to amr_ibrahim For This Useful Post: |
