11-13-2017, 05:49 | #136 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001279F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:19 |
11-13-2017, 05:49 | #137 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001279F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
11-13-2017, 05:50 | #138 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 -pBoot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
11-13-2017, 05:52 | #139 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001210F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
11-14-2017, 13:33 | #140 (permalink) | |
Freak Poster Join Date: Sep 2016 Location: **S♦A♦R** Age: 29
Member: 2621055 Status: Offline Sonork: 100.1675233 Thanks Meter: 144 | Quote:
PROBLEM ALL LOADER CM2 SPD/MTK/QLM NO BODY ANSWER FROM 48 HOUR ON THIS POST http://forum.gsmhosting.com/vbb/f296...oader-2286353/ | |
11-19-2017, 17:01 | #141 (permalink) |
Junior Member Join Date: Mar 2008
Member: 723549 Status: Offline Thanks Meter: 1 | having problem with reading i7i pattern lock..cm2 info posted down plz help... ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v4 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! FlashMode Set : Ok! Reading PatternLock ... [Info] : UserData is big! Result can be empty! PatternLock Not Set! Elapsed: 00:00:36 Reconnect Power/Cable! |
11-20-2017, 07:19 | #142 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | New version released - http://forum.gsmhosting.com/vbb/f296...-more-2289406/ |
11-20-2017, 07:21 | #143 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
We are waiting for a long time ! | |
11-20-2017, 09:35 | #144 (permalink) | |
Member: 723549 Status: Offline Thanks Meter: 1 | waiting for reply.... Quote:
11-22-2017, 16:38 | #146 (permalink) |
No Life Poster Join Date: Apr 2010 Location: chirala
Member: 1293395 Status: Offline Sonork: 100.1657302 Thanks Meter: 87 | detel d900 lock reset and read frimwear done by cm2 hear is the log Card found : A3B50E6B , v0136 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.01 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR Load : Detel D900 SC6533G_4MiB_COMMON_TARGET_2017-05-20_102922.ilod Device Info Details : [0] : COMMON_TARGET [1] : 8809 [2] : 8809e2 [3] : CT8851C [4] : pasw_hs8292u [5] : flsh_spi32m [6] : st7735s/gc9102d_hsd_jym [7] : bf3a01serial/byd3703_km [8] : rdabt_8809 [9] : rdafm_8809e [10] : release [11] : 2017-05-20_10:29:22 [12] : test_version Load Ok! Operation : Identify [ v1.01 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.01 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.01 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00200000 BOOT_INIT : 0x48F823EE BOOT_MODE : UNKNOWN Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Reset Settings [ v1.01 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00200000 BOOT_INIT : 0x7CF823AA BOOT_MODE : UNKNOWN Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v1.01 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00200000 BOOT_INIT : 0x58F823AE BOOT_MODE : UNKNOWN Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read Flash [ v1.01 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.48.2 InternalVersion: g0d6cbdbd Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Read done, 0x00400000 Verify FlashContent MCU verified CAL verified FAC verified Device Info Details : [0] : COMMON_TARGET [1] : 8809 [2] : 8809e2 [3] : CT8851C [4] : pasw_hs8292u [5] : flsh_spi32m [6] : st7735s/gc9102d_hsd_jym [7] : bf3a01serial/byd3703_km [8] : rdabt_8809 [9] : rdafm_8809e [10] : release [11] : 2017-05-20_10:29:22 [12] : test_version Saved to : C:\Users\Sri Vignasai Mobiles\Desktop\107\ Saved as : SC6533G_4MiB_COMMON_TARGET_2017-05-20_102922.ilod Done! Elapsed: 00:00:56 Reconnect Power/Cable! Operation : Reset Settings [ v1.01 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.48.2 InternalVersion: g0d6cbdbd Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Preparing PMT Verifying PMT Erasing 1474560 bytes FileSystem format done! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
12-15-2017, 16:49 | #147 (permalink) |
Junior Member Join Date: May 2017
Member: 2715217 Status: Offline Thanks Meter: 0 | Info B310e SC6530 Card found : 748B734A , v0136 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.01 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR Operation : Identify [ v1.01 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6530 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
12-20-2017, 07:02 | #149 (permalink) |
Freak Poster Join Date: Jul 2004 Location: nigeria Age: 41
Member: 73254 Status: Offline Sonork: 100.1583566 Thanks Meter: 13 | I don't know why I keep on sending message finding solution and cm2 team never attempt to my problem, what is the essence of buying your product if you cannot provide solution, this is more the 8month I have been requesting for solution. Too bad.. I am not happy at all, thus is not a small phone, I don't mind pay for solution. telma RDA/COOLSAND 8851a, 8851cl network unlock, invalid sim or sim close i have 2000 pieces as well, please is urgent TELMA V034+ TELMA V034+DUO TELMA X034+DUO please find me solution.... is a small phone Feature phone HERE ARE THE DUMP FILE https://www.4shared.com/rar/fDEoqksF..._Read_out.html |
12-20-2017, 12:10 | #150 (permalink) | |
And what is the problem with your 2000 phones exactly ? | |
