05-11-2018, 16:09 | #170 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Nigeria
Member: 2124174 Status: Offline Thanks Meter: 19 | Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL Start Failed! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable! please help me on how to fix this proble |
05-11-2018, 17:17 | #171 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
05-12-2018, 01:06 | #172 (permalink) |
Member: 2124174 Status: Offline Thanks Meter: 19 | Spreadtrum SC6530/6531/A/C/E/G not detected have been try all cpu tab Spreadtrum SC6530/6531/A/C/E, but no success.. all i see is Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary ERROR : FDL Start Failed! Error : Loader send failed! Wrong model selected! Select correct one! Reconnect Power/Cable!. help me team |
05-12-2018, 14:52 | #173 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Make sure about you have really try select another mode. Make sure about phone, which you connect, belongs to this CPU. And finally - mention device brand and model. |
05-15-2018, 11:41 | #174 (permalink) |
Junior Member Join Date: May 2018 Location: Shibtola more
Member: 2834456 Status: Offline Sonork: 100.650600 Thanks Meter: 0 | (Itel) model:- it5600 Card found: S/N : **************** Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! please help me on how to fix Last edited by liton7697; 05-15-2018 at 11:43. Reason: please help me on how to fix |
05-22-2018, 17:08 | #177 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | That because you need remove WHOLE cm2scr dir and install again. NOT put inside CM2SCR dir anything! |
05-23-2018, 10:08 | #178 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: Rawalpindi Pakistan Age: 37
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | Quote:
for repair security Last edited by qaiser_ali123; 05-23-2018 at 10:15. | |
05-23-2018, 10:27 | #179 (permalink) |
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | when i remove DongleManager.exe and DongleManager.txt from cm2scr Folder C:\InfinityBox\CM2SCR sm2scr is runing fine. but i need to Trun off uk edition For repair Security Option. so how can fix this |
