08-29-2017, 09:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | Infinity-Box Chinese Miracle Qualcomm Module [QLM] Infinity team.... i have problem with InfinityBox CM2QLM not see usb but other box see just CM2QLM not see Card found : 5xxxxx , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! working with all other (BST sam+umt+mrt+HUA Xiaomi +nckDongle Qualcomm+UniTool +miracle_box) but not work with Infinity-Box Chinese Miracle Qualcomm Module [QLM] how can solved this problem |
08-29-2017, 09:11 | #2 (permalink) | |
No Life Poster Join Date: Sep 2013 Location: Kotla Arab Ali Khan(PAK)
Member: 2016954 Status: Offline Thanks Meter: 345 | Quote:
The Following User Says Thank You to GsmKotla For This Useful Post: |
08-29-2017, 09:17 | #3 (permalink) |
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | i try this solutionhttp://forum.gsmhosting.com/vbb/f296.../#post12254319 but the same problem |
08-29-2017, 09:24 | #6 (permalink) |
No Life Poster Join Date: Nov 2008 Location: manila ph. Age: 39
Member: 895644 Status: Offline Sonork: 098765 Thanks Meter: 161 | UN-INSTALL ALL QUALCOM REBOOT PC AND RE INSTALL ALL OF THIS 1-EmergencyDownloadDriver 2-WinUsbCoInstallers 3-WinUsbCompatIdInstaller 4-WinUsbDriversExt |
The Following User Says Thank You to jhames47 For This Useful Post: |
08-29-2017, 10:01 | #9 (permalink) | |
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | UN-INSTALL ALL QUALCOM REBOOT PC ok Quote:
UN-INSTALL ALL QUALCOM INSTALL ALL OF THIS 1-EmergencyDownloadDriver 2-WinUsbCoInstallers 3-WinUsbCompatIdInstaller 4-WinUsbDriversExt | |
08-29-2017, 10:10 | #10 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Try install this setup ur problem will be solve Nokia_Care_Suite_5.6.134.1513 www.gsmflashfile.com |
08-29-2017, 12:39 | #11 (permalink) | |
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | ALL Driver DONE +ALL DRIVER SUCCEEDED... Quote:
but the same problem THE SAME PROBLEM | |
08-29-2017, 13:00 | #13 (permalink) |
Member: 895644 Status: Offline Sonork: 098765 Thanks Meter: 161 | i face the same error almost 6 months ago but i succeed bro. dont installl qusb manual just install auto and dont reboot pc. try trace the samsung driver if install un install 1st just try again i know you will succeed too |
08-29-2017, 13:53 | #14 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | @-=MR_Gsm=-, Dont post no of screenshots of other tools. Better search over forum, why you are not getting success with Infinity tool.. The matter is driver. Infinity CM2 QLM Does not work with QDLoader 9008 Port. You need to install driver from infinity support Driver download link Here You should also follow this tutorial.... http://forum.gsmhosting.com/vbb/f296...video-2160627/ Good Luck |
The Following User Says Thank You to chandanps18 For This Useful Post: |
