05-18-2011, 13:30 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 449617 Status: Offline Thanks Meter: 1,034 | Infinity-Box "MModule" v3.90: .PowerTel-M6000 model supported (flash read/write, sp-unlock, user code, repair, emptyboard flashing) .ZTE-X632 model supported (flash read/write, sp-unlock, user code, repair, emptyboard flashing) .Huawei-G6622 model supported (flash read, sp-unlock, user code) .Azumi-S101 operations improved (sp-unlock improved) .Philips-F511 model included in list (flash read/write, sp-unlock, user code, repair, emptyboard flashing) .Philips-X116 model included in list (flash read/write, sp-unlock, user code, repair, emptyboard flashing) .Alcatel-355 operations improved .Alcatel-383 operations improved .Alcatel-706 operations improved .Alcatel-708 operations improved .Motorola-M290 operations improved .firmware database updated Infinity-Box 6 (six) years non-stop free updates and support: Infinity-Box - News Online software activation system (based on Infinity-Credits) launched - World biggest flash files database for several thousands brands/models - Infinity-Box Variants & Packages - Follow us on Twitter Last edited by YellowBoss; 07-01-2020 at 10:21. Reason: legacy links fix |
The Following 5 Users Say Thank You to gsmstyle_1 For This Useful Post: |
06-09-2011, 03:49 | #5 (permalink) |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | huawie g2100 need but no one team suport this im don.t know why a lot up peaple posting and waiting but no 1 action which is so much wanted |
06-13-2011, 05:14 | #6 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1397516 Status: Offline Thanks Meter: 2 | I have ZTE X632 from movistar, i tried the funtions sp-unlock user code and standart mode, flash read/write whith the back up flash and the support flash, repair eeprom and the result still phone locked, please help thanks in advance |
07-08-2011, 05:01 | #7 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Mr yellowboss can helpme I have problems unlocking this phone and tried all the methods and the result is always white screen that says NV RAM 3453 455 23 pd: use the latest version of MModule |
07-08-2011, 05:14 | #8 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Metodo unlock: read codes Modelo: ZTE-X632 Checkeando datos, espere... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! 19200 autodetect Iniciando [6223:8A08]... CPU: MT6223 alta velocidad de boot On chip: 0011:56F8:000C status: FF Connecting at 19200, wait... Deje de presionar el boton power ahora ! Telefono detectado, espere... Hardware: MT6223,E08 Dato: 2000.00.00 Version: 1.0 Version: Z525.C136.HW1.SW7.V2.06_VE Version: YUANDA23C_09A_HW ==================== 86 byte(s) read imei: xxxxxxxx coneccion Ok 193 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 0000 181 byte(s) read Leyendo datos... 228 byte(s) read Peligro: unknown lock version: E4000000 error: La operación falló ! Finalizado, tiempo usado: 21 sec Quite/coloque la bateria ahora ! |
07-08-2011, 21:06 | #9 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Device: ZTE-X632 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:74A6:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: M23_Z525_C136_HW1_SW7_PCB01_GPRS_MT6223P_S00.Z525_ C136_HW1_SW7_V2_05_VE.BIN project-id: Z525.C136.HW1.SW7.V2.05_VE, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2CEA0000000000 Backup required data Done ====> Patch required data ... .................................... lock area found .................................... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................................. required data found flash: EC257E25082501:2CEA0000000000 flash: EC257E25082501:2CEA0000000000 Write: area 1 (pass 1) ............................... area 1 patch applied Ok Special operation Done ====> Write ... flash: EC257E25082501:2CEA0000000000 flash: EC257E25082501:2CEA0000000000 Write: lock-area-1 flash: EC257E25082501:2CEA0000000000 flash: EC257E25082501:2CEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 12 sec Remove/Install battery now ! unlock not working |
07-08-2011, 21:07 | #10 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | COM31 [VCP0] selected module v3.96 Device: ZTE-X632 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:74A6:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: M23_Z525_C136_HW1_SW7_PCB01_GPRS_MT6223P_S00.Z525_ C136_HW1_SW7_V2_05_VE.BIN project-id: Z525.C136.HW1.SW7.V2.05_VE, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-X632_M23_Z525_C136_HW1_SW7_PCB01_GPRS_MT6223P_S00. Z525_C136_HW1_SW7_V2_05_VE__ffs... file saved: C:\InfinityBox\MModule\ZTE-X632_M23_Z525_C136_HW1_SW7_PCB01_GPRS_MT6223P_S00. Z525_C136_HW1_SW7_V2_05_VE__ffs_20110708-150923.B0E.bin flash: EC257E25082501:2CEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch Special operation Done ====> Write ... flash: EC257E25082501:2CEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 23 sec Remove/Install battery now ! allways white screen and error nvram_sec.c,657,5069 9676 0 repair bug of X632 |
i WANT TO BUY NOKIA BOX !!! | Eric | Wanted Products | 8 | 02-14-2011 13:23 |
New NOKIA BOX - New Prices | gsmEsteve | Main Sales Section | 0 | 12-03-2000 03:43 |
New Nokia BOX for you!!! | gsmEsteve | Main Sales Section | 0 | 11-18-2000 17:09 |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
