02-17-2021, 20:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | SC9850x Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_1GB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : KONROW_EASY55_V10_20181224 Ver. Incmt : 51419 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-12-05 Build Time : 24.12.2018 Product Brand : KONROW Product Model : EASY55 Product Name : EASY55 Product Device : EASY55 Product Manfct : KONROW Product Info : EASY55 Product Board : EASY55 Board Platform : sp9850ka AndroidVer : 8 VlnrLevel : 0x00 SP9850KA__KONROW__EASY55__8.1.0__KONROW_EASY55_V10 _20181224__OPM2.171019.012__EASY55 Read : prodnv.img ExtSparse : Compression ratio : 44% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Fail to readout data from device! ERROR : 00000084:84000000FF7B7E00 GEN : UNKNOWN RESPONSE! >>> Error : Failed to read data! Unexpected end of data! >>> Check cable, connection and drivers! Reconnect Power/Cable! |
02-17-2021, 20:11 | #2 (permalink) |
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | FORMAT FSS FAIL Code: Operation : Format FS / Reset Settings [ v2.11 ] Mode : Reset Settings [ Format FS ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_1GB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe failed! Reconnect Power/Cable! Done! Elapsed: 00:00:30 Code: Operation : Format FS / Reset Settings [ v2.11 ] Mode : Forced [ Format FS / Fix ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_1GB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : Forced Wipe Wipe Ok : Forced Wipe Reconnect Power/Cable! Done! Elapsed: 00:00:56 |
02-18-2021, 14:00 | #4 (permalink) |
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | now i am checking imei is damaged i think calibration also damaged iam trying to restore nv bckp i have always this error with trying 2 method Code: Device Connected! BootVersion : SPRD3 Boot : PAC : KONROW_EASY55_V10_20181224-user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x21 PMTMng : Update failed! ERROR : 000000AC:AC000000FF537E00 SEC : NOT ENABLE TO WRITE FLASH! >>> Error : Flashing failed! >>> Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process Reconnect Power/Cable! Operation : Write NVM [ v2.11 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : KONROW_EASY55_V10_20181224-user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! NVRM : 0086AD931D08__l_fixnv2.nvm NVMng : Init DST Failed to update NV! ERROR : 000000AC:AC000000FF537E00 GEN : UNKNOWN RESPONSE! >>> Error : Failed to write data! >>> Check previous message for more info! Reconnect Power/Cable! Operation : Write NVM [ v2.11 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : KONROW_EASY55_V10_20181224-user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! NVRM : 0086AD931D08__l_fixnv2.nvm NVMng : Load 0x10 NVMng : Init SRC NVMng : Security DAMAGED! NVMng : Trying use recover mode NVMng : Trying use recover mode NVMng : Init DST NVMng : NV has been destroyed! Skip item, because SWAP mode selected! Failed to update NV! ERROR : 00000084:84000000FF7B7E00 GEN : UNKNOWN RESPONSE! >>> Error : Failed to write data! >>> Check previous message for more info! Reconnect Power/Cable! Operation : Flash Firmware [ v2.11 ] Setting : Update NVRAM : True Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Write NVM [ v2.11 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : KONROW_EASY55_V10_20181224-user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! NVRM : 0086AD931D08__l_fixnv2.nvm NVMng : Init DST Failed to update NV! ERROR : 000000AC:AC000000FF537E00 GEN : UNKNOWN RESPONSE! >>> Error : Failed to write data! >>> Check previous message for more info! Reconnect Power/Cable! Operation : Flash Firmware [ v2.11 ] Setting : Update NVRAM : True Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : KONROW_EASY55_V10_20181224-user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x21 PMTMng : Update failed! ERROR : 000000AC:AC000000FF537E00 SEC : NOT ENABLE TO WRITE FLASH! >>> Error : Flashing failed! >>> Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process Reconnect Power/Cable! Operation : Flash Firmware [ v2.11 ] Setting : Update NVRAM : False Setting : Force NVRAM : True Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : KONROW_EASY55_V10_20181224-user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x21 PMTMng : Update failed! ERROR : 000000AC:AC000000FF537E00 SEC : NOT ENABLE TO WRITE FLASH! >>> Error : Flashing failed! >>> Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process Reconnect Power/Cable! |
02-20-2021, 16:46 | #7 (permalink) | |
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | Quote:
cpu sp9850ka FULL contact with cm2 FULL FLASH Code: Operation : Flash Firmware [ v2.11 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 ProtoEx : Forced FlashWrite enabled! FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x21 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : recovery.img CODE : tos.bin CODE : tos.bin CODE : sml.bin CODE : sml.bin UBOOT : u-boot.bin UBOOT : u-boot.bin CODE : boot_logo.bmp CODE : fastboot_logo.bmp FSIMG : persist.img CODE : modem_wcn.img CODE : modem_l.bin CODE : gdsp_l.bin CODE : ldsp_l.bin CODE : pm_sys.bin CODE : boot.img FSIMG : system.img FSIMG : cache.img FSIMG : vendor.img CODE : vbmeta.img CODE : vbmeta.img FSIMG : userdata.img UBOOT : u-boot-spl.bin ERASE : MISC ERASE : FLASH_L ERASE : UBOOT_LOG Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:03:38 FULL WIPE+ FRP REMOVE Code: Operation : Format FS / Reset Settings [ v2.11 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 ProtoEx : Forced FlashWrite enabled! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:29 WRITE FULL NV 1 REPAIR CALIBRATION Code: Operation : Write NVM [ v2.11 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 ProtoEx : Forced FlashWrite enabled! FDL : Control transfered! Boot Done! NVRM : 354718094407961__l_fixnv1.nvm NVMng : Init DST NVMng : NVM block updated! NVMng : Post-Processing Reconnect Power/Cable! Done! Elapsed: 00:01:12 | |
The Following User Says Thank You to MDK23 For This Useful Post: |
