Old 02-17-2021, 20:00   #1 (permalink)
MDK23's Avatar
Member: 467636
Sonork: Double Kanon
Thanks Meter: 2,654
SC9850x
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_1GB_SS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
FDL : Control transfered!
Boot Done!
Device info :
Patch Level : OPM2.171019.012
Display ID : KONROW_EASY55_V10_20181224
Ver. Incmt : 51419
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-12-05
Build Time : 24.12.2018
Product Brand : KONROW
Product Model : EASY55
Product Name : EASY55
Product Device : EASY55
Product Manfct : KONROW
Product Info : EASY55
Product Board : EASY55
Board Platform : sp9850ka
AndroidVer : 8
VlnrLevel : 0x00
SP9850KA__KONROW__EASY55__8.1.0__KONROW_EASY55_V10 _20181224__OPM2.171019.012__EASY55
Read : prodnv.img
ExtSparse : Compression ratio : 44%
Read : phase.cfg
Read : recovery.img
Read : tos.bin
Read : sml.bin
Read : u-boot.bin
Read : boot_logo.bmp
Read : fastboot_logo.bmp
Fail to readout data from device!
ERROR : 00000084:84000000FF7B7E00
GEN : UNKNOWN RESPONSE!
>>> Error : Failed to read data! Unexpected end of data!
>>> Check cable, connection and drivers!
Reconnect Power/Cable!
Old 02-17-2021, 20:11   #2 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,654
FORMAT FSS FAIL
Operation : Format FS / Reset Settings [ v2.11 ]
Mode : Reset Settings [ Format FS ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
Wipe failed!
Done!
Elapsed: 00:00:30
FORCE FORMAT FSS WIPE OK BUT PHONE REBOOT ALONE
Mode : Forced [ Format FS / Fix ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
Wipe Ok : Forced Wipe
Done!
Elapsed: 00:00:56
Old 02-17-2021, 21:11   #3 (permalink)
llcoolr's Avatar
Member: 53408
Sonork: 100.1593951
Thanks Meter: 1,261
try reflash firmware kho
https://www.dzgsm.com/vb/threads/80557-konrow-easy-55/
The Following User Says Thank You to llcoolr For This Useful Post:
Old 02-18-2021, 14:00   #4 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,654
now i am checking imei is damaged i think calibration also damaged
iam trying to restore nv bckp i have always this error with trying 2 method
Device Connected!
BootVersion : SPRD3
Boot : PAC : KONROW_EASY55_V10_20181224-user.pac
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
PMTMng : Load PMT
PMTMng : 0x21
PMTMng : Update failed!
ERROR  : 000000AC:AC000000FF537E00
SEC : NOT ENABLE TO WRITE FLASH!
>>>  Error : Flashing failed!
>>>  Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process
Operation : Write NVM [ v2.11 ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
NVRM  : 0086AD931D08__l_fixnv2.nvm
NVMng  : Init DST
Failed to update NV!
>>>  Error : Failed to write data!
>>>  Check previous message for more info!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
NVMng  : Load 0x10
NVMng  : Init SRC
NVMng  : Security DAMAGED!
NVMng  : Trying use recover mode
NVMng  : Init DST
NVMng  : NV has been destroyed! Skip item, because SWAP mode selected!
Operation : Flash Firmware [ v2.11 ]
Setting   : Update NVRAM : True
Setting   : Force NVRAM : False
Setting   : Update PMT   : True
Wait for device ...
>>>  Device not found!
>>>  Remove battery, cable. Check cable and connection. Repeat operation!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
NVMng  : Init DST
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
PMTMng : Load PMT
PMTMng : 0x21
Setting   : Update NVRAM : False
Setting   : Force NVRAM : True
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
PMTMng : Load PMT
PMTMng : 0x21
Old 02-19-2021, 09:51   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Enable ForceExtWrite option in Platform tab.
Repeat need procedure again.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 02-19-2021, 09:52   #6 (permalink)
JayDi's Avatar
Member: 462970
The Following User Says Thank You to JayDi For This Useful Post:
Old 02-20-2021, 16:46   #7 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,654
we can say realy good box with good team & support
cpu sp9850ka FULL contact with cm2
FULL FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : INFINITY FW PACKAGE
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
ProtoEx : Forced FlashWrite enabled!
Boot Done!
PMTMng : Load PMT
PMTMng : 0x21
PMTMng : Update PMT Ok!
FSIMG  : prodnv.img
CODE  : recovery.img
CODE  : tos.bin
CODE  : tos.bin
CODE  : sml.bin
CODE  : sml.bin
UBOOT  : u-boot.bin
UBOOT  : u-boot.bin
CODE  : boot_logo.bmp
CODE  : fastboot_logo.bmp
FSIMG  : persist.img
CODE  : modem_wcn.img
CODE  : modem_l.bin
CODE  : gdsp_l.bin
CODE  : ldsp_l.bin
CODE  : pm_sys.bin
CODE  : boot.img
FSIMG  : system.img
FSIMG  : cache.img
FSIMG  : vendor.img
CODE  : vbmeta.img
CODE  : vbmeta.img
FSIMG  : userdata.img
UBOOT  : u-boot-spl.bin
ERASE : MISC
ERASE : FLASH_L
ERASE : UBOOT_LOG
Flashing finished!
Done!
Elapsed: 00:03:38
FULL WIPE+ FRP REMOVE
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:29
WRITE FULL NV 1 REPAIR CALIBRATION
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
FDL : 0x0002
Boot Done!
NVRM  : 354718094407961__l_fixnv1.nvm
NVMng  : Init DST
NVMng  : NVM block updated!
NVMng  : Post-Processing
Done!
Elapsed: 00:01:12
The Following User Says Thank You to MDK23 For This Useful Post:
Page generated in 0.16568 seconds with 8 queries
