01-28-2021, 22:16 | #64 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | OPPO CPH1725 Cannot connect.... Is this not support or...? Quote:
01-28-2021, 23:06 | #67 (permalink) |
Freak Poster Join Date: Sep 2017 Location: anywhere
Member: 2754769 Status: Offline Thanks Meter: 276 | add MT6799 Code: Card found : 1F877D05 , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.19 Load IDBase v125162 Ok! Update configuration ... Update Ok! Load IDBase v125162 Ok! Operation : HW Report [ v2.19 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM292) MODE : BOOTROM PORT : 292 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6799 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Whitney TYPE : MODERN RAPHAEL BROM : MEID : FAEA93BB25EEAA0FD398340D4FFEC974 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 7C13986E4E6E6FB610CEF8AC8D6F6F2048AF37088CB8F8C15E699A5B94A9721F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6799 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Info : LEGACY : HW reporting feature unavailable for current device! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Done! Elapsed: 00:00:22 Operation : HW Report [ v2.19 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM292) MODE : BOOTROM PORT : 292 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6799 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Whitney TYPE : MODERN RAPHAEL BROM : MEID : FAEA93BB25EEAA0FD398340D4FFEC974 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 7C13986E4E6E6FB610CEF8AC8D6F6F2048AF37088CB8F8C15E699A5B94A9721F BROM : LOG : F0: 102B 0000 F7: 0000 0000 V0: 0000 0000 [0001] AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6799 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Info : LEGACY : HW reporting feature unavailable for current device! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Done! Elapsed: 00:00:16 |
01-29-2021, 02:05 | #68 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
01-29-2021, 02:08 | #69 (permalink) | |
Yes, there can be such. We fixed that in next release! | |
01-29-2021, 05:18 | #72 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: pilapil marangle
Member: 1190283 Status: Offline Thanks Meter: 67 | oppo a31 unable to read frimware Quote:
