Old 05-05-2021, 14:46   #1 (permalink)
Member: 1043909
Thanks Meter: 60,926
Infinity Chinese Miracle-2 MTK/MediaTek v2.23 - New models and features
As ordinary, unique functions and methods released
Core
Changed: Protocol updated ( Raphael/Legacy )
NewSOC: ChipConfig for MT6833 activated ( under test )
Changed: BootHelper updated
Changed: Fixed SW reaction to conenction/power issues ( lags/stuck removed )
Changed: META core updated
! Allow connect from now to device, which already in META mode
! Identify by default not reboot device, other operations - reboot
Changed: Fixed Preloader mode handling on some driver versions
Changed: Fixed META init on some devices
Changed: SLA: Development feature to generate and send error reports automatically for unsupported devices
! No any data will be sent without user request
Flasher
Changed: UltraFlash engine updated
MemoryTool
Feature: Activated "Init GPT/PMT with resize" option
! Allow in some cases fix: Stuck/freeze/Rebooting issues on cheap encryption-enabled devices with cheap memory installed
! Issue found on MiPlay, some Infinix and other devices ( should work on more models range )
! Feature work by decrease UserData space size to avoid "bad blocks"
Service
Changed: SmartReset updated
Changed: SmartReset Extra mode updated
! SmartReset Extra acts like ordinary ones, but make additional, brand-required operations :
- Reset MiAcc for XIAOMI ( non-permanent )
- Reset FlyMe acc for MEIZU
- Reset DEMO mode on VIVO devices ( under test )
! Other, vendor-specific scripts can be included by users requests
Changed: "Restore Backup" option updated
! Clean and prepare files for correct restore in secure devices revised
Firmware Reader
Changed: New types supported
Changed: Internal Database updated
Other
Changed: Some general changes and fixes
Changed: Connection mode fixes
Download link #1
Download link #2
Download link #3
How to upload files to support
Infinity-Box as nobody else since year 2005
The Following 57 Users Say Thank You to YellowBoss For This Useful Post:
Old 05-05-2021, 14:47   #2 (permalink)
Member: 1043909
What is it:
Professional people know a lot about damaged and semi-damaged flash chip. In most case the onlybway to repair phones with semi-damaged flash chip is SOLDERING.
Not so many people ready to make this work.
But now you can try to fix phone with semi-damaged flash chip WITHOUT SOLDERING!
The idea is: set limit for flash chip space usage. So f.e. if your phone has 16Gb flash and part of it is damaged you can set a limit and use only 10Gb instead of 16Gb.
In this case phone will have less memory but phone WORKS!
During last days it was done many tests and result is: 6 out of 11 completely dead phones become alive WITHOUT SOLDERING!
Yes yes, I know, you are very smart and you may say "and what?" The amswer is: make your phone alive without soldering and see result after some time!
HowTo :
1. Init MemoryTool
2. By clicking right mouse button, select in context menu Extra -> Init GPT/PMT with resize
3. Select scatter for your device ( you always can read it from this device )
4. In new menu, by moving track, select desizer user size. Left - decrease, right - increase.
5.1 In order of TEST try recommend set left corner with smaller User Size.
5.2 In case of success test - operation can be repeated with bigger value.
6. Close MemoryTool. Make SmartReset to accept changes.
The Following 44 Users Say Thank You to YellowBoss For This Useful Post:
Old 05-05-2021, 14:47   #3 (permalink)
Member: 1043909
Virustotal report
Be careful and select only really working antivirus tools. Tools marked RED COLOR gives false alert and can not be treated and trusted.
The Following 12 Users Say Thank You to YellowBoss For This Useful Post:
Old 05-05-2021, 15:02   #4 (permalink)
Member: 2649950
Thanks Meter: 33
1. NAND smart for 6580 like devices?
2. IMEI repair while flash full?
2. Dead NAND substitution to sd card in sdcard slot?
Old 05-05-2021, 15:25   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
3. Dead NAND substitution to sd card in sdcard slot?
Preference and courtesans are follow.
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM11)
MODE : BOOTROM
PORT : 11
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
...................//FF-CUTOFF//............................
FF : INIT : eMMC init Ok!
MMC_CSD: D02701320F5903FFF6DBFFEF8E40400D
TEMP_WRITE_PROTECT: False
PERM_WRITE_PROTECT: False
MMC_CID: 1501004B3758564D4201xxxxxxxxCD
VENDOR : SAMSUNG : OEM : 0 : ID : 4B3758564D42
VENDOR : SAMSUNG : K7XVMB
SERIAL : 23232323232 ( 0xAxxxxxxx) , MF : 3/2015
EXTCSD [REVISION]         : rev1.7 ( eMMC 5.0 )
EXTCSD [ERASE_GROUP_DEF]  : 0x0400
EXTCSD [BOOT_BUS_WIDTH]   : 0x00
EXTCSD [PARTITION_CONFIG] : 0x48
EXTCSD [SIZE] : MARKET : 8 GB || ACTIVE : 7,28 GB || 0x1D2000000
EXTCSD [EOL] : EOL status : Normal  ( Less than 80% reserved blocks used )
EXTCSD [EOL_A] : SLC status : 10% - 20% used
EXTCSD [EOL_B] : MLC status : 10% - 20% used
The Following 8 Users Say Thank You to JayDi For This Useful Post:
Old 05-05-2021, 15:29   #6 (permalink)
Member: 1043909
@Z_Felix
Have you tried anyting?
Old 05-05-2021, 15:35   #7 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 161
Verry good update ...
Old 05-05-2021, 15:46   #8 (permalink)
Member: 1043909
You live in a free World. If you don't like something you are free to get something else somewhere else.
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 05-05-2021, 16:05   #9 (permalink)
Member: 2649950
Thanks Meter: 33
Originally Posted by YellowBoss View Post
@Z_Felix
now only oppo a1k hw report
Card found : 860027B7 , v0148
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.23
Load IDBase v428174 Ok!
Update configuration ...
Update Ok!
Load IDBase v429178 Ok!
Operation : HW Report [ v2.23 ]
HWreport : Mode : eMMC
PTFN : MediaTek USB Port (COM73)
MODE : BOOTROM
PORT : 73
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN RAPHAEL
BROM : MEID : 1F4ABAAD0FFF1A9D987B13366EE1016E
BROM : BOOTROM
MODE : 0_base : BASE_v2112 | Manual : Disabled
BROM : SOCID : 54A07055ADBFA60889510FBDE4174EDC723FB28BEE8CDC0229 6E3A7176483262
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0003
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x0003A000 [ 232,00 KB ]
DRAM: 0x80000000 [ 2,00 GB ]
EMMC: 150100514436334D42038E1B9056B633
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x01000000 [ 16,00 MB ]
USER : 0x747C00000 [ 29,12 GB ]
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 659992CDD680F51285EB1061F87654B6
DA : USB : HIGH-SPEED
Boot done!
Memory Info :
CID : 150100514436334D42038E1B9056B633
MEM : VEN : SAMSUNG | OEM : 01 | DEV : QD63MB
DAT : Size: 29820 MB, Max.Speed: 52000 kHz, blklen(512), nblks(61071360), ro(0)
EXT_CSD Info :
EXT_CSD rev. : v1.8 ( MMC v5.1 )
CSD struct rev. : v1.2
Supported command sets : 1h
HPI features : 1h
BG operations support : 1h
BG operations status : 0h
Correct prg. sectors : 0h
1st init time after part. : 3000 ms
Min. write perf.(DDR,52MH,8b): 0h
Min. read perf. (DDR,52MH,8b): 0h
TRIM timeout: 0 ms
Secure feature support: 55h
Secure erase timeout : 8100 ms
Secure trim timeout : 5100 ms
Access size : 3584 bytes
HC erase unit size : 512 kbytes
HC erase timeout : 300 ms
HC write prot grp size: 8192 kbytes
HC erase grp def. : 0h
Reliable write sect count: 1h
Sleep current (VCC) : 7h
Sleep current (VCCQ): 7h
Sleep/awake timeout : 26214400 ns
Sector count : 3a3e000h
Min. WR Perf. (52MH,8b): 0h
Min. Read Perf.(52MH,8b): 0h
Min. WR Perf. (26MH,8b,52MH,4b): 0h
Min. Read Perf.(26MH,8b,52MH,4b): 0h
Min. WR Perf. (26MH,4b): 0h
Min. Read Perf.(26MH,4b): 0h
Power class: 0
Power class(DDR,52MH,3.6V): 0h
Power class(DDR,52MH,1.9V): 0h
Power class(26MH,3.6V) : 0h
Power class(52MH,3.6V) : 0h
Power class(26MH,1.9V) : 0h
Power class(52MH,1.9V) : 0h
Part. switch timing : 2h
Out-of-INTR busy timing: ah
Card type : 57h
Command set : 0h
Command set rev.: 0h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 2h
Boot area write prot : 0h
User area write prot : 0h
FW configuration : 0h
RPMB size : 16384 kbytes
Write rel. setting : 1fh
Write rel. parameter: 14h
Start background ops : 0h
Enable background ops: 2h
H/W reset function : 1h
HPI management : 0h
Max. enhanced area size : 747h (15261696 kbytes)
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
General purpose 1 size : 0h (0 kbytes)
General purpose 2 size : 0h (0 kbytes)
General purpose 3 size : 0h (0 kbytes)
General purpose 4 size : 0h (0 kbytes)
Enh. user area size : 0h (0 kbytes)
Enh. user area start: 0h
Bad block mgmt mode: 0h
Overall status :
MLC status : 0% - 10% used
SLC status : 0% - 10% used
RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE]
Done!
Elapsed: 00:00:16
The Following 3 Users Say Thank You to Z_Felix For This Useful Post:
Old 05-05-2021, 16:11   #10 (permalink)
Member: 2649950
Thanks Meter: 33
but same SP while flash
MODE : BOOTROM
PORT : 73
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6765
EMI : SRC : preloader_oppo6762_18540.bin
EMI : CNT : 0009
EMI : [00] : eMMC : DDR3 : ID : 150100515836334142 : VEN : SAMSUNG | DEV : QX63AB : RAM : [ 2,00 GB ]
EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ]
EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ]
EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ]
EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ]
EMI : [05] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ]
EMI : [06] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4,00 GB ]
EMI : [07] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ]
EMI : [08] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ]
EMI : Init EMI from PRELOADER
EMMC:
Boot done!
[FL] : HW verification passed!
SEC_DL : False (RAPHAEL)
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000002188000
Erase : 0x000000000AA88000 : 0x0000000001D00000
ERR : 0xC0040030
ERR : MMC ERROR
ERR : 0x00000000|0x00000000
[DEBUG] : ERASE_BREAK , Skip erase
Old 05-05-2021, 16:24   #11 (permalink)
Member: 2649950
Thanks Meter: 33
other SP same model flash done
PTFN : MediaTek USB Port (COM71)
MODE : BOOTROM
PORT : 71
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : MEID : 2FD2DBD8221C119810D6DBC7758EB7BA
BROM : BOOTROM
BROM : SOCID : B85BDA627D9A5B493388C52CF0F13EA1464CFA1E2ACD88AC0F C005A902F87CEB
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6765
EMI : CNT : 0009
EMMC: 150100514436334D4203636290D5B6D7
EMMC:
RNID : E4B90040F56BFC584C01D7147C36DDEB
Boot done!
[FL] : Pre-Erase
Erase : 0x000000000E788000 : 0x0000000006000000
Erase : 0x0000000015800000 : 0x0000000000800000
Erase : 0x0000000019000000 : 0x0000000000200000
Erase : 0x0000000019500000 : 0x0000000008900000
Erase : 0x0000000025E00000 : 0x0000000595A00000
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader backup copy ...
Update bootloader backup copy Ok!
Write : RECOVERY
Write : OPPORESERVE2
FAIL : SEC : IMG TYPE MISMATCH
Write : VBMETA
Write : MD1IMG
Write : SPMFW
Write : SCP1
Write : SCP2
Write : SSPM_1
Write : SSPM_2
Write : LK
Write : LK2
Write : BOOT
Write : LOGO
Write : DTBO
Write : TEE1
Write : TEE2
Write : ODM
Write : VENDOR
Write : SYSTEM
Write : CACHE
Write : USERDATA
Ultra : OK! [ All failed parts successfully flashed ]
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:04:03
Reconnect Power/Cable!
Old 05-05-2021, 16:34   #12 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 480
What a Fast update.... Alwayes give care for customer thank you much much respect for Dev and the all team
BR || Baya
Old 05-05-2021, 16:45   #13 (permalink)
Member: 2649950
Thanks Meter: 33
Any ideas how to detect whats is wrong with flash ic ?
and whats is "FAIL : SEC : IMG TYPE MISMATCH" ?
Old 05-05-2021, 17:15   #14 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
ultra flashing will take care care of this error in last
The Following 2 Users Say Thank You to kamal_singla For This Useful Post:
Old 05-05-2021, 17:39   #15 (permalink)
Member: 1524998
Thanks Meter: 76
imei 0 repair for huawei y9a cpu helio g80
Page generated in 0.39701 seconds with 8 queries
