03-05-2018, 12:12 | #196 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 425 [MSM8917] ID_BLOCK_S : 1FEDA089 ID_BLOCK_I : 000560E1 ID_BLOCK_L : 85C2417DCFC60A6D6478C8BF13837B5C ID_BLOCK_L : B7413B9A5D7C16C4B30ACFBAC531FDA0 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! MIAccount reset passed! |
The Following User Says Thank You to okello For This Useful Post: |
03-13-2018, 16:09 | #200 (permalink) |
Junior Member Join Date: Nov 2014 Location: Jhapa, Nepal
Member: 2301577 Status: Offline Thanks Meter: 0 | vivo y 53 pattern unlock, frp wipe data 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 3DE20F18 ID_BLOCK_L : 01DCC71E890CC5811DDF9D619D80344F ID_BLOCK_L : BBE07A89678BAA1B7AF31556F11B2E6C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RE1BMB Boot Ok! ERROR : FS verification fail! Encrypted or damaged! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 3DE20F18 ID_BLOCK_L : 01DCC71E890CC5811DDF9D619D80344F ID_BLOCK_L : BBE07A89678BAA1B7AF31556F11B2E6C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RE1BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
03-20-2018, 14:27 | #202 (permalink) |
Freak Poster Join Date: Sep 2014 Location: islamabad pakistan Age: 39
Member: 2266425 Status: Offline Thanks Meter: 58 | Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 810 [MSM8994] ID_BLOCK_S : 002FC762 ID_BLOCK_E : 00310000 ID_BLOCK_L : 1E0A6232EA47B7963C8A085E2A04E358 ID_BLOCK_L : ACBF142BD7DE8FD2DED1411E2CB2E89F Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
03-22-2018, 19:20 | #203 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,105 | Add to support Qualcomm firmware without included loader because if i select firmware folder not inclus loader i get an error and please add custom flash from Factory firmware by select an unselect partitions files |
03-22-2018, 22:55 | #205 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
03-25-2018, 17:22 | #208 (permalink) |
Major Poster Join Date: Nov 2013 Location: localhost Age: 40
Member: 2075091 Status: Offline Thanks Meter: 25 | @JayDi please add reset button for flash tab in qlm. Since when choosing a firmware, the bootloader is used from it, rather than the qlm. I have to restart the program. |
03-25-2018, 20:40 | #209 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Enough press cancel in selection tab to disable FW. I will rebuild FW selection to new design, which will be used in MTK module. With right-click menu, something like in BESTv2 for BB5. |
03-25-2018, 20:44 | #210 (permalink) | |
Member: 2075091 Status: Offline Thanks Meter: 25 | Quote:
Nice! Thanks Паша! looking forward to 2.0 ... Отправлено с моего iPhone используя Tapatalk | |
