04-24-2018, 17:52 | #245 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | sorry Bro, same vibrate only, i read Fulldump.img 62 gb, and write it, bootloader lock-unlock by fastboot mode, try reflash till Last ver tissot_images_V.9.5.10.0.ODHMIFA_20180405.0000.00_ 8.0_b9e697ed56 mobile is Dead, only vibrate. Note: vol down+power Hold together, device manager show fastboot but display black. |
04-24-2018, 18:23 | #246 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: gsm world
Member: 1741973 Status: Offline Thanks Meter: 115 | How about for damage dongle cm2 Quote:
04-27-2018, 15:13 | #250 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Hint already given, just need to search. Br. Infinity Box Team. | |
05-07-2018, 16:39 | #251 (permalink) |
Freak Poster Join Date: Dec 2013 Location: cote d'ivoire
Member: 2076643 Status: Offline Sonork: 100.1650096 Thanks Meter: 70 | XIAOMI REDMI NOTE 5A MI AND FRP ACCOUNT REMOVED [IMG]Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : DFB2A212 ID_BLOCK_L : 0C75D6F4784FB1E4EDE77134A81AE2D5 ID_BLOCK_L : 7A7AF05766B1518976D1F2F582F42065 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x45 , VENDOR : SANDISK , NAME : DL2032 Boot Ok! MIAccount reset passed! Device may relock back on WiFi/Network enable! Done! Elapsed: 00:00:21 Reconnect Power/Cable! Card found : B8C2315C , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Card found : B8C2315C , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : DFB2A212 ID_BLOCK_L : 0C75D6F4784FB1E4EDE77134A81AE2D5 ID_BLOCK_L : 7A7AF05766B1518976D1F2F582F42065 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x45 , VENDOR : SANDISK , NAME : DL2032 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable![/IMG] |
The Following User Says Thank You to hermann07 For This Useful Post: |
05-08-2018, 15:00 | #252 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 931121 Status: Offline Thanks Meter: 100 | oppo a37fw read pattern done Card found : 64C1CE3F , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 25C67771 ID_BLOCK_L : 768EE412BD2956510E63EDF23D048CBC ID_BLOCK_L : 9DF05EF1E26DDD566B4A0FC4CE213F1C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f Device : A37f AndroidVer: 5.1.1 SWVersion : A37fEX_11.A.28_INT_028_201710081545 Manufact. : OPPO SysPatch : LMY47V DevComTime: 10/8/2017 9:26:49 AM QLMxCPU : MSM8916 USERData : NORMAL GCSec : EMPTY Done! Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 25C67771 ID_BLOCK_L : 768EE412BD2956510E63EDF23D048CBC ID_BLOCK_L : 9DF05EF1E26DDD566B4A0FC4CE213F1C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f Device : A37f AndroidVer: 5.1.1 SWVersion : A37fEX_11.A.28_INT_028_201710081545 Manufact. : OPPO QLMxCPU : MSM8916 DevInfo : MSM8916__OPPO__OPPO__ANDR_v5.1.1__A37f__A37f__A37f __A37fEX_11.A.28_INT_028_201710081545 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sec.dat [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : pnvbak.img [Read Ok] : lsplash.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : driver.iso [Read Ok] : reserve4.bin [Read Ok] : reserve_exp1.bin [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin [Read Ok] : gpt_main2.bin [Read Ok] : cdt.mbn [Read Ok] : gpt_backup2.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 3094 MiB Done! Elapsed: 00:05:17 Reconnect Power/Cable! Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 25C67771 ID_BLOCK_L : 768EE412BD2956510E63EDF23D048CBC ID_BLOCK_L : 9DF05EF1E26DDD566B4A0FC4CE213F1C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 1453 Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to moniuzzaman For This Useful Post: |
05-11-2018, 08:20 | #253 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | please add this cpu Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : EE8E953B ID_BLOCK_I : 0008C0E1 ID_BLOCK_E : 00510000 ID_BLOCK_L : 06CDEFABA0483D03B70F5DB70B75BDB3 ID_BLOCK_L : 29ACBD43F5BA51503D3EDE1020ADAFDA Use CM2 Internal Loader Error : Prepare target failed! Unsupported yet CPU! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
05-12-2018, 16:32 | #254 (permalink) |
Major Poster Join Date: Sep 2010 Location: Dubai Age: 35
Member: 1390266 Status: Offline Sonork: 100.1668465 Thanks Meter: 6 | oppo r11 not support with cm2 qlcom please update this phone 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : E9ADF932 ID_BLOCK_E : 00510000 ID_BLOCK_L : F9C41654A9B7341C800656AE0282B244 ID_BLOCK_L : 088B9A62D29BB2B15C01FFF3C38C8EFB Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
05-13-2018, 15:48 | #255 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Biafra
Member: 2128067 Status: Offline Thanks Meter: 16 | Htc desire 530 unsupported please infinity team kindly support this phone, HTC DESIRE 530 T MOBILE NETWORK LOCKED Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 07002936 ID_BLOCK_L : C5A57EA51DB6AE8AEF0D0A277E5E7FC4 ID_BLOCK_L : 8062ED9759B49AA9300FE0A08B18261E Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
