07-31-2020, 16:50 | #76 (permalink) |
No Life Poster Join Date: May 2013 Location: Earth
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | now display inside ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0006 Device : RKM755_3126 #RECOVER_KEY: 1,1,0,20,0 ExtInfo : 4.4.2 SoC CPU : 312A SoC PDT : 2014 SoC SWN : 0429 SoC REV : V100 Flash CSx : 0x00 Flash Type : ADDE14A742 [ NAND ] Flash Vend : HYNIX Flash Size : 0x0000000212000000 ( 8.28 GiB ) Flash Info : 4194304/16384/32/40/1 Connect Ok! Wiping UserData ... Wipe DATA Ok! Done! Elapsed: 00:00:02 |
08-01-2020, 23:16 | #79 (permalink) |
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | it shows or displayed inside you cannot see on screen unless flash light like when light ic of device is bad thanks Last edited by nduka; 08-01-2020 at 23:21. |
08-02-2020, 08:38 | #80 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Make sure you have left device for 10-15 minutes and reboot/check again. That not should affect anything at all, except some HW fault, like water or short circuit on led high power line. | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
08-11-2020, 14:07 | #84 (permalink) |
Insane Poster Join Date: Dec 2004 Location: Peru Callao Age: 45
Member: 100918 Status: Offline Thanks Meter: 13 | Aoc A741 Frp Operation : Identify [ v2.02 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0100 SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C644432A5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020C000000 ( 8.19 GiB ) Flash Info : 8388608/16384/32/60/1 Connect Ok! Board Platform : rk3126c Patch Level : NHG47K Display ID : A741_20180322 Ver. Incmt : user.liuh.20180322.182614 Ver. CodeName : REL Ver. Release : 7.1.2 Sec. Patch : 2018-03-01 Build Time : 1521714374 Product Model : A741 Product Brand : AOC Product Name : A741 Product Device : A741 Product Board : rk30sdk Product Manfct : AOC Board Platform : rk3126c Product Info : rk3126c Done! Elapsed: 00:00:18 Operation : Reset Settings [ v2.02 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0100 SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C644432A5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020C000000 ( 8.19 GiB ) Flash Info : 8388608/16384/32/60/1 Connect Ok! Remove FRP 0 ... FRP removed! Wiping UserData ... Wipe DATA Ok! Done! Elapsed: 00:00:08 frp not removed https://drive.google.com/file/d/1S84...ew?usp=sharing |
The Following User Says Thank You to maxcer24 For This Useful Post: |
08-14-2020, 16:22 | #85 (permalink) |
Member: 100918 Status: Offline Thanks Meter: 13 | Reading Flash Err0r Leotec LETAB731 Pulsar Qi Operation : Read Firmware [ v2.02 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0006 SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C64643CA5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020A000000 ( 8.16 GiB ) Flash Info : 8388608/16384/32/40/1 Connect Ok! Reading Flash Content ... Error : Failed to convert data! Erased/Damaged device??? Send log and report.log to support! Include device info also! |
08-28-2020, 13:37 | #90 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote: Probably your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support for 1 or 2 years - https://www.infinity-box.com/buy/ | |
