11-17-2016, 17:54 | #76 (permalink) |
Freak Poster Join Date: Nov 2008 Location: uganda Age: 50
Member: 894224 Status: Offline Thanks Meter: 96 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 62 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 3701FF454D4330344710F60000FAC28D Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
11-17-2016, 21:34 | #81 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: IBADAN
Member: 1927114 Status: Offline Sonork: YOU ASK ME Thanks Meter: 26 | Quote:
This is CM2SPD thread! | |
11-18-2016, 19:23 | #89 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | If we add SC6xxx and rest ancient devices, then will be started much cry about "it not working on all devices/killing" or whatever else. We don't have access to much test samples, unlike fresh one models. We can't build something universal without test material. |
11-19-2016, 05:58 | #90 (permalink) | |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Quote:
Bro, please just study the few ones that fall on your hands and try your best to develop solutions for them. We will use without complaints. As time goes on, there will be an improvements. Day in and day out, more and more models operating on that ancient CPU are being manufactured and pumped into various regions. We need to deal with them and I believe only your tool can deal with those CPUs better and more efficiently. Thanks and BR... Last edited by Kwesi_Roy_GH; 11-19-2016 at 06:07. | |
The Following User Says Thank You to Kwesi_Roy_GH For This Useful Post: |
