Old 05-10-2017, 13:06   #76 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Originally Posted by Taguro-GSMLover View Post
Hello Jaydi. Is there a possibility that you can also add autodetect loaders on SPD CPU??? Just like you did on MTK and QLM. Very usefull if you can add this in next updates.
Current way require make some "cable", which is can be done by not much peoples infact. Need solder skills and some spareparts.
Old 05-10-2017, 13:15   #77 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
work for mé
=== DongleManager [Infinity] v1.70 [10/05/2017 12:13:42] ===
Box/Dongle type selected: [BEST]
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 0101778714D11292
Box/Dongle found: [BEST]
Reading...
Serial No (S/N): 000000
Firmware version: 0122.02
=== Process started: 10/05/2017 12:13:43 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication successfull
Service stage 1 confirmed
Securing session...
Session secured ok
Upgrading dongle...
Wait 4-5 minutes ! DO NOT disconnect Box/Dongle !
Applet upgrade ok
Identification Ok. Finalizing...
Finalizing ok
Process completed
=== Process finished: 10/05/2017 12:13:55 ===
=== DongleManager [Infinity] v1.70 [10/05/2017 12:13:55] ===
=> Activations:
- 00: Infinity-Box/Dongle v.0136
- 03: [BEST] v.0122
Old 05-10-2017, 13:41   #78 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 708
now the server working good i also update successfully......
Old 05-10-2017, 13:42   #79 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 708
Originally Posted by JayDi View Post
because users help is zero
In such way it will out never.
sir actually what you want from us?????
Old 05-10-2017, 13:56   #80 (permalink)
Member: 1755008
Sonork: Yuanita Aprilia
Originally Posted by gsmkiller173 View Post
=== DongleManager [Infinity] v1.70 [5/10/2017 11:42:37] ===
Searching...
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 00032839FF021982
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 38632839
Firmware version: 0135.02
=== Process started: 5/10/2017 11:42:41 ===
Connection to server failedSocket Error # 10061
Connection refused.
what can i do ?
just download dongle manager v1.70 and update your cm2 dongle, my problem solve
Old 05-10-2017, 14:26   #81 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
after install spd 1.26 imei repair option not found help
Old 05-10-2017, 14:28   #82 (permalink)
Member: 307225
Thanks Meter: 59
Sir, During Update Smart Card (Dongle Disconnected) Now No Card Show In Dongle Manager
What To Do ? Please Help Me Out. If You Need Log From Dongle Manager Will Post Here.
Old 05-10-2017, 14:30   #83 (permalink)
Member: 924142
Thanks Meter: 12
update problem master
=== Process started: 5/10/2017 21:25:13 ===
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
Old 05-10-2017, 15:26   #84 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
What help you need brother ?
Br - srinibas
Old 05-10-2017, 15:39   #85 (permalink)
Member: 1600534
Thanks Meter: 25
The best team in the world GSM
The Following User Says Thank You to kata23 For This Useful Post:
Old 05-10-2017, 15:58   #86 (permalink)
Member: 2243325
Sonork: 01715634715
Thanks Meter: 28
=== DongleManager [Infinity] v1.70 [5/10/2017 20:56:50] ===
Searching...
HWID: 01018B5A20281292
Reading...
Serial No (S/N): CDE08B5A
=== Process started: 5/10/2017 20:56:51 ===
Securing session...
Session secured ok
Upgrading dongle...
Applet upgrade ok
Finalizing ok
Process completed
=== Process finished: 5/10/2017 20:57:06 ===
=== DongleManager [Infinity] v1.70 [5/10/2017 20:57:06] ===
Box/Dongle type selected: Infinity-Box/Dongle
Firmware version: 0136.02
=> Activations:
The Following User Says Thank You to gsmshapla For This Useful Post:
Old 05-10-2017, 17:27   #87 (permalink)
Member: 451521
Thanks Meter: 317
Not found supported security type!
Phone found! [ 7 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
Write new security data :
IMEI1 : 860483038418700
IMEI2 : 860483038469224
Not found supported security type! Try make repair without "FlashMode" option!
Elapsed: 00:00:21
Reconnect Power/Cable!
The Following User Says Thank You to Tom_ptm For This Useful Post:
Old 05-10-2017, 17:29   #88 (permalink)
Member: 451521
Thanks Meter: 317
Phone found! [ 7 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : P909D_32v4
Model Brand : TRUE
Model Device: P909D_32v4
AndrVersion : 6.0
BaseBand CPU: P909D_32V4
CompileDate : 27/8/2016 10:20:31
Project Ver : SMART_4G_MAX_4.0_V0.17_2016_08_27
Model Ext : SMART 4G MAX 4.0
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:21
Old 05-10-2017, 17:43   #89 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by Tom_ptm View Post
Phone found! [ 7 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Brand : TRUE
AndrVersion : 6.0
Elapsed: 00:00:21
Phone found! [ 7 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Elapsed: 00:00:21
Hello. Make FW read operation. Send link to that FW.
The Following User Says Thank You to JayDi For This Useful Post:
Old 05-10-2017, 17:57   #90 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Spd 7731C New Cpu Add Plz
The Following User Says Thank You to Tanha0321 For This Useful Post:
Page generated in 0.25967 seconds with 8 queries
