Old 05-10-2017, 19:55   #91 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Originally Posted by Tanha0321 View Post
Spd 7731C New Cpu Add Plz
Just select correct boot and all will work.
The Following User Says Thank You to JayDi For This Useful Post:
Old 05-10-2017, 20:38   #92 (permalink)
Ouzigzag's Avatar
Member: 1753151
Sonork: 100.1658597
Thanks Meter: 332
Good !
Please add SC8810/6820
The Following 2 Users Say Thank You to Ouzigzag For This Useful Post:
Old 05-10-2017, 21:39   #93 (permalink)
Member: 2116484
Thanks Meter: 62
Bro
When update using DongleManager Message appear it say
"No updates found for yor Smart-Card Do Not try more today !"
The Following User Says Thank You to abd5alla1 For This Useful Post:
Old 05-11-2017, 02:56   #94 (permalink)
Member: 1846766
Thanks Meter: 13
== DongleManager [Infinity] v1.70 [5/11/2017 9:57:18] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 0000F5FA7CEC4082
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): D2F5F5FA
Firmware version: 0135.02
=== Process started: 5/11/2017 9:57:19 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
that is my problem also... how can fixed it?
The Following User Says Thank You to Android-04 For This Useful Post:
Old 05-11-2017, 03:49   #95 (permalink)
Member: 542287
Thanks Meter: 20
the same problem for update dongle infinity,How to fix the dongle? Now can not use it for new update
The Following User Says Thank You to por hy For This Useful Post:
Old 05-11-2017, 04:03   #96 (permalink)
shaikhmobiles's Avatar
Member: 551708
Thanks Meter: 39
where is IMEI repair section in v1.26???????????????????????
The Following User Says Thank You to shaikhmobiles For This Useful Post:
Old 05-11-2017, 04:55   #97 (permalink)
muhammad khalid's Avatar
Member: 313337
Sonork: 100.1582697
Thanks Meter: 106
open dongle manager
"Set UK Edition off"
and Process
now open software you will find imei option in CM2MTK
and
Delete C:\InfinityBox\CM2SPD\UK.txt
now open software you will find imei option in CM2SPD
thanks to you all by gsmzaman
The Following User Says Thank You to muhammad khalid For This Useful Post:
Old 05-11-2017, 05:00   #98 (permalink)
Member: 2497406
Sonork: 100.1672478
Thanks Meter: 50
after upgrade may dongle no imei repair option plz provlam solve
The Following User Says Thank You to gsmragim For This Useful Post:
Old 05-11-2017, 05:10   #99 (permalink)
Member: 2043843
Thanks Meter: 39
Bugs report.
[QUOTE=srinibas;12492197][B]What help you need brother ?
If something not supported by last version then send report and logs to Team . Every CM2 module has it saprate team which work on update R&D ... Just send report to Team . As on last two post jydi sir aak to read firmware from phone and provide link after upload but I don't thing user will do it .
And if possible send sample of phone which not supported.
The Following User Says Thank You to vishal110094 For This Useful Post:
Old 05-11-2017, 05:26   #100 (permalink)
Member: 542287
Thanks Meter: 20
not found imei in my dongle
Old 05-11-2017, 05:26   #101 (permalink)
tartcell18's Avatar
Member: 1595088
Thanks Meter: 184
any clear explnation why its hard to update this card
The Following User Says Thank You to tartcell18 For This Useful Post:
Old 05-11-2017, 05:37   #102 (permalink)
Member: 542287
Thanks Meter: 20
=== DongleManager [Infinity] v1.70 [5/11/2017 11:32:04] ===
Box/Dongle type selected: [BEST]
Card-Reader: FT SCR2000 0
HWID: 00045A8901171292
Box/Dongle found: [BEST]
Reading...
Serial No (S/N): 05C55A89
Firmware version: 0122.02
=== Process started: 5/11/2017 11:32:06 ===
Old 05-11-2017, 05:37   #103 (permalink)
Member: 1687222
Thanks Meter: 9
Searching...
Reading...
The Following User Says Thank You to newmultan For This Useful Post:
Old 05-11-2017, 05:45   #104 (permalink)
JayDi's Avatar
Member: 462970
That mean expired support period.
Old 05-11-2017, 05:59   #105 (permalink)
Member: 307225
Thanks Meter: 59
@JayDi
Please Check Support Email. Waiting For Support Reply Regarding My Dongle Not Found
The Following User Says Thank You to Abid Hussain For This Useful Post:
Page generated in 0.22593 seconds with 8 queries
