07-11-2017, 12:37 | #16 (permalink) | |
No Life Poster Join Date: Sep 2009
Member: 1109337 Status: Offline Thanks Meter: 197 | Quote:
02-09-2018, 21:47 | #23 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | New software will be released as soon as it will be finished and well tested. Others sell future promises but Infinity do not give any promises. Infintiy simply work. If you have even small knowledge about programming you must know that work is not easy. If you have good programming skills and if you are ready to help with research you are welcome to contact us anytime to discuss cooperation. If you need any hot solution urgently you can try to find something other good working on market. |
The Following 4 Users Say Thank You to YellowBoss For This Useful Post: |
02-10-2018, 12:06 | #26 (permalink) |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | don,t worry copy poster also ready as get release the update couple days theye are will too same support ,as you got qlm update after that is support to every one |
02-10-2018, 13:18 | #27 (permalink) |
Freak Poster Join Date: Dec 2015 Location: GREAT YAR*****
Member: 2495115 Status: Offline Thanks Meter: 34 | I'm getting same result. Alcatel A3 XL. Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Am I mising something ? Steve |
