09-03-2010, 09:16 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 50
Member: 116314 Status: Offline Thanks Meter: 147 | infinity does not boot any set |
09-03-2010, 12:30 | #2 (permalink) | |
Is it brand new box or this box was working before but now it's damaged ? | |
09-07-2010, 16:30 | #5 (permalink) |
Member: 116314 Status: Offline Thanks Meter: 147 | i was trying to format a china gfive fone with rx tx tp solder method. after connecting power and pressing power key i found my set was not detected later i tried with many fones and found myself under this problem. thats all. can i claim for new infinity hardware from gpg or my reseller or if i can repair by mprog method if any solution exist. thanx in advance. |
09-07-2010, 17:18 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | It may be box hardware fault (result of bad soldered wires) or drivers problem. At first try to re-install drivers. Where to get latest FTDI drivers: 1. latest FTDI VCP drivers is here: Virtual COM Port Drivers How to re-install FTDI drivers in case of any problems or conflicts with another boxes: 1. disconnect box from PC 2. uninstall FTDI drivers: C:\Windows\system32\ftdiunin.exe 3. reboot PC 4. connect box to PC and install FTDI drivers from Infintiy-Box package |
09-08-2010, 03:28 | #7 (permalink) |
Freak Poster Join Date: May 2008
Member: 779599 Status: Offline Thanks Meter: 59 | i experienced also that brother , my infinity box product by gpg xware also damage there interface easily damage not good harware , if you connect rx tx not in exact pin out for example you put rx or tx wire to b+ then your box will be damage , so we hope that gpg manufacturer will include protection to their hardware if we mis to connect proper rx tx so that the hardware will not damage |
09-08-2010, 11:21 | #8 (permalink) | |
09-09-2010, 18:58 | #12 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If your box was damaged as a result of wrong rx/tx/gnd wires connection to phone PCB - for sure reseller never replace this box by warranty. In this situation you have to open box and in most cases FT232 chip replacement can solve all problems. FT232 chip can be found in any electronic components shop, it's quite cheap chip. |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
