infinity pin finder need help hello infinity team pls help me in solving my problem with my pinfinder. my infinity box cant detect pinder pls help me . action taken: remove set up and reinstall again no luck. install latest pinfinder set up . but still no luck i doubt why it happen i use my pinfinder the other day its working , but yesterday when i use it . the screen appear like this until now: Initializing... software version: 1.23 Dongle S/N: Dongle firmware version: 0116 Initializing PinFinder... Initializing database... base/user database version: 01/01 Loading configuration... Initializing cable list... Initializing platforms... Initialization finished searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter searching adapter at COM1 (115200)... warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries can't find adapter searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter done searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter searching adapter at COM1 (115200)... warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries can't find adapter searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter done searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter searching adapter at COM1 (115200)... warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries can't find adapter searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter done searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter searching adapter at COM1 (115200)... warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries can't find adapter searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter done searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter searching adapter at COM1 (115200)... warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries warning: command confirmation absent warning: command confirmation absent warning: command confirmation absent too many retries can't find adapter searching adapter at COM5 (115200)... too many retries too many retries too many retries can't find adapter done |
infinity team pls help how could i really know whether my infinity box is ok or my pinfinder is ok cause i try to format the phone with correct pin out but the box dont work , which really the problem my box or the pinfinder |
i buy my box three months from now kindly give some idea on how to solve this problem |
hello! check in device manager if your infinity box hold comport number 5 |
i already check the ports the infinity box hold it , i also uninstall the port driver and reinstall again but still dont work pls help me |
check rj45 first pin 5v if this volt absent no detect pinfinder. pinout 1---5v+postive 2---rx 3---tx 4---na 5---na 6---na 7---negative 8---negative |
i directly check the box by formating china phone using rj45 cable rx tx without pinfinder but the box dont work even i hold and press the power botton , i try to use the other software the phone run but in infinity box it does not work COM5 [VCP0] selected module v3.07 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! |
i open finder software i check the cable wire connected to the box of infinity with out connecting to the pinfinder box this is the result pinout 1-----------5v 2-----------rx 5v 3-----------tx 3.8 4-------------na 5------------na 6------------na 7------------negative 8------------negative so now wheres the problem may there is a problem in infinity box cause even i directly conect the phone to the infinity box i doesnt work COM5 [VCP0] selected module v3.07 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! |
hello! if you cant make phone formatted even without pinfinder- this means that this isn't pinfinder problem. you must continue check main infinity box. check if switches is ok etc if still nothing- you need to buy new unibox |
