08-04-2009, 18:42 | #2 (permalink) | |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software | |
Can infinity team help me with file flash Vcall 829! | duyphuong3000 | Infinity-Box | 10 | 03-21-2010 15:39 |
Infinity can't unlock MXNEC N9 chip Infineon 7880, Infinity team help me ! | coolderheart | Infinity-Box | 1 | 11-15-2009 06:12 |
infinity team help with Huawei T201 | nellabe | Infinity-Box | 4 | 10-15-2008 12:18 |
infinity team help all infinity user | TUR@N ALAM | Infinity-Box | 3 | 08-09-2008 08:59 |
@Infinity-Team Problem with C139 | imran_qasim | Infinity-Box | 1 | 09-19-2006 15:22 |
