03-30-2008, 18:48 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | what is the model of ur phone ,guess u are talking about n95/6688, post here u model and conncetor type, u will surely get pinout or u can use the easy method posted in this forum to find pinout by urslef... |
03-30-2008, 18:59 | #3 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 268712 Status: Offline Thanks Meter: 479 | 1pin-0.00v - this pinout is wrong 2pin-2.78 - it may correspond to Tx Rx signals rx 3pin-00.2v - GND signal 4pin-2.75v - it may correspond to Tx Rx signals 5pin-1.09v - LOOKS LIKE Tx Rx signals, BUT IT IS NOT! 6pin-0.00v - this pinout is wrong 7pin-4.02v - this pinout is wrong 8pin-2.89v - it may correspond to Tx Rx signals tx 9pin-3.05v - this pinout is wrong 10pin-0.00v - this pinout is wrong 11pin-1.09v - it may correspond to Tx Rx signals 12pin-0.02v - YOU DON'T NEED these fake signals with high and low voltage 3. In order to find Tx you need to put multimeter to test, diod ( "+" and "-" = beep ). When the phone is POWERED ON, Tx with GND make a sound beep. When it is TURNED OFF, it shows 600-700 ohm. find d rx tx & gnd dan connect with infinity dan click at ffs ( safe ) |
infinity team pls help??? e71+ firmware. help??nfinity team pls. help?? | vintel | Infinity-Box | 4 | 03-07-2010 11:29 |
Infinity team pls help | vpriya | Infinity-Box | 3 | 10-17-2009 16:49 |
infinity team pls... help! | tabuki | Infinity-Box | 2 | 12-23-2007 09:02 |
Infinity Team pls help me | jhay_12 | Infinity-Box | 8 | 08-27-2007 10:32 |
infinity team pls help for c261 unlock user lock | siang8788 | Infinity-Box | 4 | 01-13-2007 20:05 |
