03-29-2010, 15:29 | #1 (permalink) |
Banned Join Date: May 2007
Member: 506173 Status: Offline Thanks Meter: 32 | Alcatel ot 103 Unlock probleme module v3.28 Device: Alcatel-103X, 103A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:54E9:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM17CB40 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->0826B698 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35247103953163 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201003 29-160556.B0X.bin Finished, time used: 1 min 31 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! after unlock phone is making off and on continuesely And after repair security, phone is on normaly but still locked. |
The Following User Says Thank You to abote didier For This Useful Post: |
03-29-2010, 15:35 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,974 | For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock: 1. use "MModule" software v3.22 or newer 2. use "Write" button from software "Service" page and write original imei (from phone back label) 3. make "sp-unlock" |
The Following 4 Users Say Thank You to YellowBoss For This Useful Post: |
03-30-2010, 11:39 | #4 (permalink) |
Freak Poster Join Date: Mar 2004 Location: China SZ Age: 50
Member: 58924 Status: Offline Sonork: 1583810 Thanks Meter: 57 | Yes man that phone direct unlock is not supported by any box only infinity can do it by this proccess after many updates and hard work this mean infinity team is work hard for make the best. Br GSMDOCTOR |
The Following User Says Thank You to DOCTOR8 For This Useful Post: |
Alcatel ot-c550 unlock problem | rubeltelecom | FuriousGold | 18 | 01-20-2013 12:03 |
ALCATEL OT-s319 unlock problem. | aleem26 | Easy-Unlocker | 1 | 04-09-2009 18:23 |
Alcatel OT-C635X Unlocking Problem | maplegsm | FuriousGold | 2 | 02-16-2009 13:44 |
alcatel ot-s210x unlock problem plz help | asif_ae | Multi-Box | 7 | 12-14-2008 11:25 |
alcatel ot-c560x unlock problem | Shakeel Communication | FuriousGold | 8 | 09-16-2008 07:54 |
