Old 12-13-2010, 19:27   #1 (permalink)
Member: 882614
Sonork: 100.1608795
Thanks Meter: 141
n96
please help me
COM4 [VCP0] selected
module v3.25
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
error: can't detect CPU id
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 5 sec
Remove/Install battery now !
The Following User Says Thank You to reda86 For This Useful Post:
Old 12-13-2010, 21:23   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
looks like wrong pinout used
Old 12-14-2010, 14:36   #3 (permalink)
Member: 882614
Sonork: 100.1608795
Thanks Meter: 141
MT6318A
http://www10.0zz0.com/2010/12/14/13/720970455.jpg
http://www13.0zz0.com/2010/12/14/13/794020179.jpg
http://www5.0zz0.com/2010/12/14/13/702103780.jpg
http://www5.0zz0.com/2010/12/14/13/383950369.jpg
http://www12.0zz0.com/2010/12/14/13/180707135.jpg
please help me
Old 12-14-2010, 21:04   #4 (permalink)
Member: 148515
hello!
how did you find previous pinout?
Old 12-14-2010, 21:46   #5 (permalink)
Member: 882614
Sonork: 100.1608795
Thanks Meter: 141
give me pin out mr InfinityHylp please
Old 12-15-2010, 18:34   #6 (permalink)
Member: 148515
hello!
i can only teach you how to find needed pins using multimeter.
by measuring voltage on system connector pins
Old 12-21-2010, 14:31   #7 (permalink)
Member: 882614
Sonork: 100.1608795
Thanks Meter: 141
i have pin findr
regard ca
Old 12-21-2010, 21:01   #8 (permalink)
Member: 148515
hello!
before searching pinout you must do 3 easy steps:
1. Make sure that this is mt62xx MCU based phone.
2. Count number of pins in system connector. After this is done-
pick correspondent cable. For example if you counted 2x6 pins- it is in total 12
so no point to put L14D cable instead of correct one, L12B.
3. Select cable type, connect power crocodiles in the place of battery.
push "Power On!" in software. Now phone is powered with pinfinder power.
Try to switch it On. This is main rule for success pinout search.
(Phone must turn ON)
if it does not turn On- no point to search for pinouts. you will not find it.
Start from modifying your main infinity box to deliver more power to pinfinder.
There is one diode which must be removed and shortcutted.
Open Pinfinder User Manual on Trubleshooting section and see in pictures how this must be done.
after you get phone powered- you are ready to find phone pinout.
Set activation tries to maximum value "20"
press and Hold phone power button and start search.
Old 12-22-2010, 12:15   #9 (permalink)
Member: 882614
Sonork: 100.1608795
Thanks Meter: 141
thanks Mr.Infinityhelp
The problem has been resolved
gooood pin out in image
N96 higherzman Infinity-Box 11 04-02-2009 23:27
20 N96 FlashGames atukhi Nokia Multimedia 1 01-23-2008 05:56
+ OMG: The long awaited Nokia N96 is leaked!!! apocalypso Nokia Base Band 5 ( BB-5 ) 2 12-21-2007 14:02
need pinout nokia n96 or fake n96 sevgiesenler Chinese Cocktail 1 12-11-2007 14:28
Page generated in 0.17117 seconds with 9 queries
