01-14-2008, 21:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Paris, France Age: 45
Member: 45387 Status: Offline Thanks Meter: 53 | N96 i received a nokia N96 with bad imei i searched for pinout didnt found then i've opened it soldered tx rx gnd founded on board but nothing it didnt detected by infinity pls anyone have the pinout for the 18 pins connectors? thank's BR |
01-15-2008, 00:21 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if this test points is marked as tx/rx then they must work. try to swap wires and try again. remmber that phone Tx must go to Box Rx, and otherwise phone Rx goes to box Tx |
01-15-2008, 17:19 | #4 (permalink) |
Member: 45387 Status: Offline Thanks Meter: 53 | thank's imei repaired but i'm trying to adding french language and lp editor give me : Detected crypted Chinese Miracle file... Crypted fullflash loaded Loading fullflash file... OK Detecting language pack names and codes... Language pack description not found! Searching first signature... Error! First signature not found! Reason: You have a damaged file, or file with unsupported version. If this file from fully working phone, please, contact with support! here is the link for firmware bakcup and backup system http://rapidshare.de/files/38307701/n96.rar.html BR |
01-17-2008, 13:29 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! are you sure you read out First MCU memory? please read it once again and post here together with a log file. right now i checked your file- it is not full. must be some error while reading |
03-31-2009, 22:06 | #9 (permalink) |
Junior Member Join Date: Nov 2006 Location: Montevideo, Uruguay
Member: 398072 Status: Offline Thanks Meter: 1 | Hi, I have same phone ..... but i cant conect whith infinity for read firmware and change language with lang pack editor ..... the conexion is using pinfinder ???? or not ? |
03-31-2009, 22:19 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
04-01-2009, 13:37 | #11 (permalink) |
Member: 398072 Status: Offline Thanks Meter: 1 | Hi, I do this, and i see the message"language set: english"; i disamblit the phone, and cpu type is MT6225; I see in Documentation folder one picture with pinout of this model, I try conect using pinfinder but i cant conect .... i cant upload picture with pinout. thanks for your help กกก |
N96 Weird Flashing error | javakiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-10-2010 11:55 |
E71 and N96 died by normal FBUS flashing!! | Cake | HWK | 2 | 03-30-2010 08:10 |
need pinout nokia n96 or fake n96 | sevgiesenler | Chinese Cocktail | 1 | 12-11-2007 14:28 |
