Old 03-05-2009, 14:30   #1 (permalink)
fdsalesrep's Avatar
Member: 838185
Thanks Meter: 26
INFINITY TEAM Help
Hi...
I want to unlock Alcatel S319x...
But after flashing, Its came to a BLUE SCREEN only....
heres my last logs
==== log: [3/5/2009 11:40:40 AM] ====
COM8 [VCP0] selected
module  v2.58
Device: Alcatel-S319X
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
enhanced security fix enabled
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:3138:A00C
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
ffs offset/size: 00C00000/00400000
detect device identification#2...
detect device identification#2 finished
sim-lock status: disabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_log__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN_FFFFFFFF_20090305-114122.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CH16JB10
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
use default security area (code #3, part #1) pattern
..................counter: 01
security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_log__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN_FFFFFFFF_20090305-115030.B0X.bin
Finished, time used: 573 sec
Remove/Install battery now !
I format the phone, SMART and COMPLETE...
I flashed it to the NEW firmware...
I flashed the phone with EEPROM from the support...
But Still BLUE SCREEN... but you can make a call... But Blue Screen
How do I do now????
HELP...
bR
Old 03-05-2009, 15:27   #2 (permalink)
New Style's Avatar
Member: 252713
Sonork: 1581550
Thanks Meter: 159
what was the firware in the set before flash.
Old 03-05-2009, 15:35   #3 (permalink)
fdsalesrep's Avatar
Member: 838185
Thanks Meter: 26
Here..
==== log: [3/5/2009 11:02:38 AM] ====
module  v2.58
"format ffs" active
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
sim-lock status: enabled
Write ...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_log__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN_FFFFFFFF_20090305-110316.B0X.bin
Area: Firmware
Write: Firmware
customization: CH16AB12
done
..................security area (code #3, part #1) detecting size...
done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_log__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN_FFFFFFFF_20090305-111307.B0X.bin
Finished, time used: 626 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 03-05-2009, 15:56   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
It may be hardware <-> firmware incompatibility.
Try to flash phone with higher firmware version (select file with latest release date).
Old 03-05-2009, 15:56   #5 (permalink)
Member: 977491
Thanks Meter: 82
Thumbs up Hello friend
this is very simpel problem that you need full flash file right the full flash file.with smart right.
[email protected]
Old 03-05-2009, 16:08   #6 (permalink)
fdsalesrep's Avatar
Member: 838185
Thanks Meter: 26
Originally Posted by InfinitySupport View Post
Hello,
Hi..
What Exact File do i use???
I use This 2 New FW on the support...
but still no luck...
bR
Old 03-05-2009, 16:16   #7 (permalink)
Member: 130995
Hello,
Try to flash phone with this file: S319X-2GPWGB1_XH16DP32_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_Orange-Uk.B0M.bin
What is the results ?
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-05-2009, 17:18   #8 (permalink)
fdsalesrep's Avatar
Member: 838185
Thanks Meter: 26
Hello,
ok bro i will try....
let me finish my flashing using this file >>>> S319X-2BVGGB1_XH16CS20_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-08-28_En_Fr_Es_It_De_Virgin.B0M.bin
br
Old 03-05-2009, 18:03   #9 (permalink)
fdsalesrep's Avatar
Member: 838185
Thanks Meter: 26
Hello,
Hi again...
I My phone is ok now using this FW >>>> S319X-2GPWGB1_XH16DP32_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_Orange-Uk.B0M.bin...
But the Problem is, its Locked Again
bR
Old 03-05-2009, 18:14   #10 (permalink)
Member: 130995
Hello,
yes, it's the problem. We need a time to prepare unlock solution for latest firmware/hardware type.
We will try to make it ASAP.
I can give you some files for tests and you can try it (if you have some time) but I am not sure in success.
Will prepare and upload some files ASAP.
Old 03-05-2009, 18:21   #11 (permalink)
Member: 130995
Hello,
Files uploaded.
Try to make this:
1. download "customization" files from this folder: \flashfiles\Alcatel\S319\parts
2. flash phone with "customization" files one by one and see results (make "format ffs" checked during each flash operation)
if you will see some good results, please, test phone carefully, be sure that all buttons and functions works well.
waiting for your results.
Old 03-05-2009, 18:25   #12 (permalink)
fdsalesrep's Avatar
Member: 838185
Thanks Meter: 26
Hello,
hi...
Ok... its clear now...
can you upload the file here or give me your MSN, i will test it now, when the phone is here...
bR
Old 03-05-2009, 19:42   #13 (permalink)
fdsalesrep's Avatar
Member: 838185
Thanks Meter: 26
Hi...
Here is the Result...
I put all the costumization files that you upload at the support site....
All BUTTONS are working, receiving and making call , but the problem is this...If you are on the MENU, you did'nt go to all ICON inside there....
Hopely you will find a way to resolve this...
thank you very much INFINITY... nice Box....
regards
FDSALESREP ( turon )
The Following User Says Thank You to fdsalesrep For This Useful Post:
Old 03-05-2009, 19:57   #14 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
U may check this
http://forum.gsmhosting.com/vbb/showthread.php?t=681998
all ready clearly discussed about this problem , any way u r now on right and last way ...
we need the perfect customized firmware for this ...
Infinity can't unlock MXNEC N9 chip Infineon 7880, Infinity team help me ! coolderheart Infinity-Box 1 11-15-2009 06:12
infinity team help all infinity user TUR@N ALAM Infinity-Box 3 08-09-2008 08:59
infinity team help .:iTRi:. Infinity-Box 4 02-23-2007 11:19
infinity team help !! REALTHOMAS Infinity-Box 6 07-17-2006 17:26
@ infinity team help needed for Alcatel cable chowdary Infinity-Box 2 02-11-2006 10:52
Page generated in 0.25587 seconds with 10 queries
