09-02-2019, 11:31 | #1 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Pakistan
Member: 2684815 Status: Offline Thanks Meter: 133 | Infinix Hot 7 Pro X625 frp error Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SP.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
08-07-2020, 12:03 | #10 (permalink) | |
No Life Poster Join Date: Oct 2012
Member: 1826863 Status: Offline Thanks Meter: 32 | Quote:
Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! | |
05-03-2021, 09:25 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | this file is at Infinity support area, see Infinity folder You can try Firmware File Finder via Telegram @FlashFileSearchBot |
05-04-2021, 11:36 | #13 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: attock Age: 35
Member: 1147735 Status: Offline Thanks Meter: 156 | Quote:
mobile still dead flashing log PTFN : MTK USB Port (COM61) MODE : BOOTROM PORT : 61 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 CODE : Kibo TYPE : MODERN RAPHAEL BROM : MEID : 0A90BEC352329BB24CAB20D10AB749F2 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : INFINIX : Infinix-X625C-1 | Manual : Enabled BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001E AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6757 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6757 EMI : SRC : preloader_x625c64_h576.bin EMI : CNT : 0004 EMI : [00] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 150100575831364D42 : VEN : SAMSUNG | DEV : WX16MB : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100574331364D42 : VEN : SAMSUNG | DEV : WC16MB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] EMMC: 90014A484347386134A2CA42A567C533 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 9CCD555EB251DA65CE56EDEBF6B70FA2 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : DA USB VCOM Port (COM62) MODE : PRELOADER PORT PORT : 62 Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase [FL] : Whole Flash Erase enabled! Erase : 0x0000000000000000 : 0x0000000E8F800000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : MD1IMG FAIL : INVALID GPT ERR : 0xC0030008 ERR : INVALID GPT ERR : 0x00000000|0x0117C6F0 Error : Flashing failed! >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! itried charged battery but still before flash phone on in recovery mode | |
