infinix pr652b format error Card found : B6BA133E , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! VER : BP_R2.0.1 LEN : 10B609F1E ( 4.18 GiB ) CPU : s9863a1h10 VER : PR652B-F6317-11.0-OP-V046-20210830_2008 Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : PR652B-F6317-11.0-OP-V046-20210830.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... Server Error : Access denied: {"Message":"Access denied `00B6BA133E` auth"} >>> ERROR : Server process failed! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! Reconnect Power/Cable! |
Also failed reset frp |
Hello, Read log carefully- Quote:
Br. Infinity-Box Team. |
but i will read user name and pass enter exe but still same error please team i hope you will fix this |
tell me some thing how to fix this |
Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! >>> ERROR : FLASH FDL AUTHENTIFICATION FAILED! >>> Error : Fail to boot FDL! >>> Check previous message for more info! |
Operation : Format FS / Reset Settings [ v2.09 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : PR652B-F6317-11.0-OP-V036-20210708.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0xE8EECADC ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Wipe failed! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:08 |
infinix PR652b write flash failed? :confused:Operation : Flash Firmware [ v2.09 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : PR652B-F6317-11.0-OP-V036-20210708.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0xE8EECADC ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x4A PMTMng : Update failed! ERROR : 000000B9:B9000000FF467E00 GEN : UNKNOWN RESPONSE! >>> Error : Flashing failed! >>> Make sure device HW is ok, check battery and cable! Try hold BootKey at whole Flash Process |
