10-02-2021, 19:21 | #1 (permalink) |
Insane Poster Join Date: Feb 2015 Location: baghdad iraq
Member: 2352901 Status: Offline Sonork: no Thanks Meter: 14 | infinix problem need help please team HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : D730492D9D04EF323AD09D3C89229C7E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : EDE3E979DE0E7CF633190243467A5DEEF31571237552A74FFD 5E785A6902CA0A BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : TECNO : BASE_SECURE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: AD014839485131354146414D41444152 UFS: VEN : 0x01AD VID : H9HQ15AFAMADAR IFW : A102 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 11158DAAD2E4 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FAB475E2DDA637FDEAD87E1A35E77AF0 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : H9HQ15AFAMADAR EXT_CSD Info : [UFS] Device Desc: [UFS] life cycle check, pre_eol_info=1, life_time_est_a=1, life_time_est_b=1 [UFS] vendor id: 0x1ad [UFS] ufs id: H9HQ15AFAMADAR [UFS] ufs fwver: A102 [UFS] ufs serial number: 11158DAAD2E4 [UFS] dev_quirk = 0x10000000 [UFS] Custom force provison=0, TW size=-1GB, TW no red=1, HPB size=-1GB [UFS] info: number of active LU: 3, check OK. [UFS] info: number of Boot LU: 2, check OK. [UFS] info: LU Configuration Check OK. Bootable UFS [UFS] info: Boot LU Configuration Check OK. Active Boot LU: LU0 [UFS] Sense Data: ASC=29, ASCQ=2 [UFS] Sense Data: ASC=29, ASCQ=2 [UFS] Sense Data: ASC=29, ASCQ=2 [UFS] Sense Data: ASC=29, ASCQ=2 [UFS] info: RX HS-G3, setting is3 [UFS] info: TX HS-G3, setting is3 [UFS] info: HS-G3-2 Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE] STORAGE : OTP Status : NOT Enabled! Done! Elapsed: 00:00:13 Last edited by mustafafrs; 10-02-2021 at 19:27. |
10-02-2021, 19:25 | #3 (permalink) |
Member: 2352901 Status: Offline Sonork: no Thanks Meter: 14 | Operation : Identify [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : D730492D9D04EF323AD09D3C89229C7E BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : EDE3E979DE0E7CF633190243467A5DEEF31571237552A74FFD 5E785A6902CA0A BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : TECNO : BASE_SECURE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: AD014839485131354146414D41444152 UFS: VEN : 0x01AD VID : H9HQ15AFAMADAR IFW : A102 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 11158DAAD2E4 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FAB475E2DDA637FDEAD87E1A35E77AF0 DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Device Erased or Damaged >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
