06-22-2019, 01:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | infinix x622 icon fix and baseband fix done solution 1)sec backup (from working phone with good baseband) 2)OPEN MEMTOOL on cm2qlm then mark all partions and erase be patient process takes time 5 min or so 3)use hqxa v1.19 to write firmware https://mega.nz/#!OXwAgIYB!L2o86ImBI...mSKRBQlEo3brcY(use google they are a lot of guides and vids on how to flash with emmc factory tool) firmware credits HOVATEK 4)after flash restore SEC backup using cm2qlm this fix baseband and network ICONS ARE BACK AND FULL NETWORK LOGS Code: Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : D75A608E ID_BLOCK_L : 1BED877FDE44717C2B00F0DD1A61F1D9 ID_BLOCK_L : 314CF25D5EC169FA1FDEB3687AB5A3A8 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GD6BMB Boot Ok! Backup Security Partitions Backup : FSG Backup : MODEMST1 Backup : MODEMST2 Backup saved to : Backup\MSM8937_[0004F0E1]_D75A608E_SEC\ Done! Elapsed: 00:00:37 Code: Operation : Memory Tool Init [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : D75A608E ID_BLOCK_L : 1BED877FDE44717C2B00F0DD1A61F1D9 ID_BLOCK_L : 314CF25D5EC169FA1FDEB3687AB5A3A8 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GD6BMB Boot Ok! Set default path : C:\InfinityBox\CM2QLM\phdata\ Ready! Operation : Erase Memory [ v1.16 ] Erase selected partitions [51] [0] Erase partition : GPT Erase partition Ok! [1] Erase partition : MODEM Erase partition Ok! [2] Erase partition : FSC Erase partition Ok! [3] Erase partition : SSD Erase partition Ok! [4] Erase partition : SBL1 Erase partition Ok! [5] Erase partition : SBL1BAK Erase partition Ok! [6] Erase partition : RPM Erase partition Ok! [7] Erase partition : RPMBAK Erase partition Ok! [8] Erase partition : TZ Erase partition Ok! [9] Erase partition : TZBAK Erase partition Ok! [10] Erase partition : DEVCFG Erase partition Ok! [11] Erase partition : DEVCFGBAK Erase partition Ok! [12] Erase partition : DSP Erase partition Ok! [13] Erase partition : MODEMST1 Erase partition Ok! [14] Erase partition : MODEMST2 Erase partition Ok! [15] Erase partition : DDR Erase partition Ok! [16] Erase partition : FSGALL Erase partition Ok! [17] Erase partition : FSG Erase partition Ok! [18] Erase partition : SEC Erase partition Ok! [19] Erase partition : ABOOT Erase partition Ok! [20] Erase partition : ABOOTBAK Erase partition Ok! [21] Erase partition : BOOT Erase partition Ok! [22] Erase partition : RECOVERY Erase partition Ok! [23] Erase partition : DEVINFO Erase partition Ok! [24] Erase partition : PERSIST Erase partition Ok! [25] Erase partition : MISC Erase partition Ok! [26] Erase partition : KEYSTORE Erase partition Ok! [27] Erase partition : CONFIG Erase partition Ok! [28] Erase partition : LIMITS Erase partition Ok! [29] Erase partition : MOTA Erase partition Ok! [30] Erase partition : DIP Erase partition Ok! [31] Erase partition : MDTP Erase partition Ok! [32] Erase partition : SYSCFG Erase partition Ok! [33] Erase partition : MCFG Erase partition Ok! [34] Erase partition : CMNLIB Erase partition Ok! [35] Erase partition : CMNLIBBAK Erase partition Ok! [36] Erase partition : CMNLIB64 Erase partition Ok! [37] Erase partition : CMNLIB64BAK Erase partition Ok! [38] Erase partition : KEYMASTER Erase partition Ok! [39] Erase partition : KEYMASTERBAK Erase partition Ok! [40] Erase partition : APDP Erase partition Ok! [41] Erase partition : MSADP Erase partition Ok! [42] Erase partition : DPO Erase partition Ok! [43] Erase partition : OEM Erase partition Ok! [44] Erase partition : CACHE Erase partition Ok! [45] Erase partition : SPLASH Erase partition Ok! [46] Erase partition : LOGDUMP Erase partition Ok! [47] Erase partition : VENDOR Erase partition Ok! [48] Erase partition : SYSTEM Erase partition Ok! [49] Erase partition : USERDATA Erase partition Ok! [50] Erase partition : GPTBAK Erase partition Ok! Operation finished! FOR THOSE WHO DONT HAVE WORKING PHONES FOR SEC BACKUP USE THESE FILES....ALSO HELPS RESTORE BASEBAND UNKOWN WITHOUT DOWNLOAD FULL FIRMWARE https://mega.nz/#!uVFy0IoQ!axIwwKLO6...FHSVBJKIcWW3s0 PRESS THANKS IF HELPS |
The Following 4 Users Say Thank You to nessyb For This Useful Post: |
06-22-2019, 01:44 | #3 (permalink) |
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | password cm2qlmx622infini Code: Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : D75A608E ID_BLOCK_L : 1BED877FDE44717C2B00F0DD1A61F1D9 ID_BLOCK_L : 314CF25D5EC169FA1FDEB3687AB5A3A8 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GD6BMB Boot Ok! Restore Security Partitions Write : FSG Write from : C:\InfinityBox\CM2QLM\Backup\MSM8937_[0004F0E1]_D75A608E_SEC\fsg.bin Write : MODEMST1 Write from : C:\InfinityBox\CM2QLM\Backup\MSM8937_[0004F0E1]_D75A608E_SEC\modemst1.bin Write : MODEMST2 Write from : C:\InfinityBox\CM2QLM\Backup\MSM8937_[0004F0E1]_D75A608E_SEC\modemst2.bin Done! Elapsed: 00:00:56 Reconnect Power/Cable! ICONS do you have to have car insurance to drive |
The Following User Says Thank You to nessyb For This Useful Post: |
06-25-2019, 02:26 | #5 (permalink) | |
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | Quote:
ITS ABOUT SHARING LITTLE SOLUTIONS TO COMMUNITY EVERYONE HERE HAVE IN SOME WAY FIND OWN SOLUTIONS SO DONT BRAG ABOUT IT KINDLY SHARE WITH US,YOUR GSM BROTHERS | |
The Following 2 Users Say Thank You to nessyb For This Useful Post: |
