02-25-2010, 12:25 | #1 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 532257 Status: Offline Sonork: 1624266 Thanks Meter: 64 | infinty team plz help Nktel A200 module v3.08 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:FA03:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #04 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #05 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #06 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #07 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.49508ECF.[GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX801_C OSTD_EN_01.BIN_E86028A3].rpl rom info detection finished device-id: 49508ECF rom info ver: 05 sw version: GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX801_C OSTD_EN_01.BIN project-id: DSX801_CostD_En_01, A32860E8 code offset: 00000000 ffs offset/size [01]: 00770000/00090000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00770000 standard ffs/eeprom offset confirmed: 00770000 detecting ffs/eeprom size... ffs/eeprom size: 00090000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00770000-007FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX801_C OSTD_EN_01__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\GINWAVE25_08A_GEM INI_PCB01_GSM_MT6225_S00.DSX801_COSTD_EN_01__ffs_2 0100225-161615.B0E.bin flash: EC257E25062501:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25062501:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\G INWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.DSX801_CO STD_EN_01__system_log_49508ECF_E86028A3_20100225-161633.B0X.bin Finished, time used: 2 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! rx 7 tx 3 all ok ringer ok on and off ring ok but incoming call no ring formate complete but same condition what can i do plz hel urgent |
02-25-2010, 12:49 | #4 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
Code: http://www.4shared.com/file/128216207/7a776be3/NKTEL_A200_Sim_2_MTK_6225__Flash_TOSHIBA_TC58FVM7BDD.html?s=1 | |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
infinty team plz help me | faisal_fs | Infinity-Box | 2 | 06-27-2009 15:02 |
plz help nktel A200 restart | brain00000 | Chinese Models & Cloned Phones | 2 | 06-11-2009 06:32 |
infinty team plz help lg kg270 & zong [zte a136] blink | soy | Infinity-Box | 7 | 03-24-2009 10:55 |
infinty team plz help me | sonumobilewala | Infinity-Box | 6 | 06-20-2008 20:29 |
infinty team plz help | sonuveene | Infinity-Box | 5 | 05-15-2008 15:06 |
