02-27-2016, 15:23 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | intex aqua young sc7731 problem in flashing sc7731 problem in flashing i try to select cpu 9 option 10 option & last option but cant flash cant format Code: Loading : Intex_Aqua_Young_V05_Indian_SER_20151020.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : Intex_Aqua_Young_V05_Indian_SER_20151020 FastCheck : 0x61636709 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : prodnv.img File : cache.img File : u-boot.bin File : SC7731_UMS.xml Load Ok! Operation : Flash [ v1.15 ] ======= Flash Files set for flashing : [ MCU ] : Intex_Aqua_Young_V05_Indian_SER_20151020.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : Intex_Aqua_Young_V05_Indian_SER_20151020 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Boot failed! Boot failed! Reconnect Power/Cable! |
02-27-2016, 16:09 | #3 (permalink) | |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Quote:
i already try but same issue cant flash ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Boot failed! Boot failed! Reconnect Power/Cable! | |
02-27-2016, 16:26 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, First charge battery. Select SP [SC7730..SC7731] eMMC [Generic] and flash with .pac file, no need to select Alternative LDR Mode. Keep on pressing both volume buttons for long time until booting is completely done. If still same check drivers, change usb cable/port and try again. Br. Infinity Box Support Team. |
03-01-2016, 08:52 | #5 (permalink) | |
I Try with same method but not work still my set problem not solved | |
03-01-2016, 10:18 | #8 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | If you are sure about firmware version selected is correct and same, then as Bro JayDi said- could be due to HW damage in Phone. Br. Infinity Box Support Team. |
03-01-2016, 17:24 | #9 (permalink) |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | my set done via hard reset it is having spd7731g android version 5.1 but i cant read write format in cm2 plz add this cpu in next update here is image |
03-01-2016, 18:10 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There is nothing to add. 1. Check your files next time. When you select PAC - CM2 use it as base. Deselect it first, to try standard variants. 2. There is universal reset method ( "Reset in SVC" ) , which allow make reset for such phones. Just read sometimes update logs and try thinking. Not waste own and support time for nothing. |
03-14-2016, 07:33 | #11 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
so i had been searched but not get finally i saw your post morning then i did done via hard reset 4 days i was lose my time nice post | |
